Roto-ette Tiller
this thread has 5 replies and has been viewed 464 times
Old 06-13-2019, 08:05:35 AM
Skelflyer Skelflyer is offline
Default Roto-ette Tiller
Since I see the site lists tillers I also have an old Roto-ette tiler my Grand-dad owned which was built in the 40's.I have never seen another like it,I finally got it apart and repaired and running this spring. with it's little Briggs 8FB engine.replaced a rusted bearing in the tiller unit and such.they're not too practical with the hook style tines because they load up with debris very fast but I have never seen another like it and as complicated as they are with the two piece aluminum housing and all the gearing involved I'm not surprised - a tire that is non existent as far as I can tell anymore.I wonder if there are any more out there
The Following User Says Thank You to Skelflyer For This Post:
Old 06-13-2019, 08:46:24 AM
Bruce Dorsi Bruce Dorsi is offline
Default Re: Roto-ette tiller
The B&S model 8 engines were only produced 1949-1957, so your tiller was probably built in that time period.
There is a LOT of info for your tiller at:
http://http://www.zucksrototillers.com/
Look around at that site, and if you have specific questions, contact Chuck Zuck directly. ...He is the "expert" on all things Rototiller.
The Following User Says Thank You to Bruce Dorsi For This Post:
Old 06-17-2019, 12:51:56 PM
chzuck chzuck is offline
Default Re: Roto-ette Tiller
I would sure like to see you post a photo or 2 of your machine.
Old 06-19-2019, 07:41:48 PM
Junkologist's Avatar
Images: 160
What you have is a Roto-Ette Home Gardener. There are quite a few of these still floating around. I have two myself, but no photos currently. Take care of that tire. It will be difficult to replace just as you suspect.
SmokStak member #146
Old 06-20-2019, 11:50:19 AM
Miller tire has 4.80-7 stud-tread tires.
Is this the tires in question?
Old 06-20-2019, 01:24:49 PM
No, the tire for the Home Gardener is 18 x 4.00 and has the valve stem vulcanized to the tire. Sort of like a tire and tube all in one. You could inflate the tire off of the rim.
One HG I bought had the tire cut open and a tube installed. Another fellow had communicated that he was going to see about having foam injected into the tire like some skid loader tires. Down side of installing a tube is that the rim does not actually have a ridge to hold a tire bead which the tire does not actually have.
The Following User Says Thank You to chzuck For This Post:
roto tiller 95gts Garden Tractors and Mowers 8 07-10-2015 09:59:41 AM
roto tiller roto ette 12voltdc Garden Tractors and Mowers 13 07-15-2013 10:12:05 PM
Big Roto Tiller ronny p 148 Farm Antiques and Collectibles 6 12-26-2011 07:24:17 PM
Roto-Ette/Troy-Bilt pick tines chzuck Garden Tractors and Mowers 0 07-25-2011 08:53:09 PM
Home Gardener Roto-Ette HG-1L Help! aprildeaver Antique Farm Tractors 7 02-27-2011 12:33:29 AM
