Smokstak Down Under
Cooper/R&T DC electric shearing plant
this thread has 14 replies and has been viewed 2655 times
Old 05-11-2012, 10:19:48 PM
John Ross John Ross is offline
Default Cooper/R&T DC electric shearing plant
Hi Guys this is my first thread!!! I have recently picked up a Cooper 240 v DC electric shearing plant. It consists of a Ronaldson & Tippet CH 31/2 Hp diesel <44576>,a Cooper DC generator badged "Cooper DC electric portable shearing plant <Model A> 1.25 KW @2400 RPM No 3664.There are three 1/3 HP 220 V Dc motors The shearing gear(down tubes) etc are missing and i don't know what the missing bits look like,or how they are driven (Belt,direct drive, or what!!!!) Any info would be much appreciated. John Ross Canberra ACT Aust
Bugger I can't put my photos on!!!
Old 05-12-2012, 06:38:47 AM
jelbart
Default Re: Cooper/R&T DC electric shearing plant
Here some pics from JR
ID:	135159   Click image for larger version
ID:	135160   Click image for larger version
ID:	135161   Click image for larger version
The Following 2 Users Say Thank You to For This Post:
Old 05-12-2012, 07:06:15 AM
jelbart
some more pics from john
ID:	135163   Click image for larger version
ID:	135164   Click image for larger version
ID:	135165   Click image for larger version
Old 05-12-2012, 07:13:36 AM
jelbart
more pics from JR
Old 05-26-2012, 08:44:45 PM
Question Re: Cooper/R&T DC electric shearing plant
Hi Stackers Sorry nobody knows of the Cooper DC electric shearing plant model A. I have stripped the R/T CM the big problem is wear in the piston from the gudgeon wearing the piston instead of oscillating on the bush in the small end of the conrod. Has anyone any suggestions how to repair the piston? JR
Old 05-27-2012, 03:17:12 AM
Ray Freeman Ray Freeman is offline
Ring around and see if anyone does Arc spraying.It would be simple to spray the gudgeon bore with something like Aluminium Bronze and machine it back to original. Otherwise someone may have a S/H piston.
Old 05-28-2012, 12:30:02 AM
Thanks Ray, another piston sounds good but i will keep the idea of spray buildup in mind.JR
Old 05-28-2012, 05:23:00 AM
Just out of interest,although I don't have a Cooper 240v electric shearing plant I do have a 110 volt DC set up. One of the shearing heads is a Wolseley and I think the other is a Cooper. I have the 110V DC generater and it originally had I believe a Moffat Virtue petrol engine on it.At present it has a R/T N on it that looks like it come of a Hannaford Grain Screen. It has the Hannaford dust guards etc on it.
Old 05-28-2012, 06:01:35 AM
Re Cooper /R&T DC electric portable shearing plant
Hi Ray does your DC plant have separate motors or do you have electric shearing machines like the 240 V used today???
Old 05-29-2012, 08:31:12 AM
John,I'll have a l0ok in the next few days and get back to you.
Old 06-04-2012, 08:26:44 AM
John,mine have a vertical shaft motor with a direct coupled drop tube coming out the bottom
Old 06-05-2012, 08:36:01 PM
Re Cooper R/T DC electric shearing plant
Thanks Ray that is what I expected, what I have has me really baffled. I still haven't located a piston!! BUGGER JR
Old 06-06-2012, 04:29:26 AM
Darryl Darryl is offline
the way i've fixed that sort of piston/gudgion problem is put piston in 4 jaw chuck and bore hole out true and then hone little end bush the same size and make a new gudgion to suit. the hardest part is setting up piston, i set up by the cir clip grooves with a pointed wire to set it true. i didnt put new cir clip grooves back in it, i made brass caps that sat in gudion hole in piston on either side of pin.
The Following User Says Thank You to Darryl For This Post:
Old 06-06-2012, 04:34:03 AM
Ian Long Ian Long is offline
HI, Try Don Reid in Brisbane for replacement piston. He owns vintage engine spares and his phone/fax number is
(07)3200 5282. Regards Ian
Old 06-06-2012, 07:12:21 AM
Thanks Ray I shall give him a call when I get around to measure the bore and gudgeon and check that the gudgeons I have are serviceable. I will post progress for your ifo.JR
The Following User Says Thank You to John Ross For This Post:
Rosebery Shearing Plant David Nicolson Smokstak Down Under 12 07-04-2012 10:05:18 PM
10 Cw Electric Plant BILLHUT Onan Generators 2 11-09-2007 10:52:25 AM
Wolseley/Cooper Sheep Shearing Equipment Kevin F. Antique Engine Archives 1 10-09-2004 05:01:41 PM
Electric Plant Larry Kastens Antique Engine Archives 2 12-17-1999 04:29:44 AM
RE; Electric plant Ken Majeski Antique Engine Archives 0 12-16-1999 11:52:26 PM
