1905 IHC 3HP Vertical - First Startup in years!
this thread has 10 replies and has been viewed 2760 times
Old 10-01-2014, 12:10:40 AM
Craig Solomonson Craig Solomonson is offline
Default 1905 IHC 3HP Vertical - First Startup in years!
Finally got around to starting up the IHC Vertical after years of sitting idle. The fuel pump was siezed but a little friendly persuasion by Noel Maggert solved that problem. Thanks Noel! This is a 100% original engine with about half of the original paint still intact. John Wanat made a tank that will fit below the engine between the skids.
The Following 61 Users Say Thank You to Craig Solomonson For This Post:
Old 10-01-2014, 01:56:31 AM
Luckster1075 Luckster1075 is offline
Default Re: 1905 IHC 3HP Vertical - First Startup in years!
Very Nice!! I want one!
Old 10-01-2014, 09:17:45 AM
Rich Mueller Sr's Avatar
Rich Mueller Sr Rich Mueller Sr is offline
NICE one, still looking for one that got sold at Dads sale no.952 flat plate, Famous verticle, was NOT no where near that good of shape!!........
United Gasoline Engine Registry www.augermo.com
Old 10-01-2014, 10:23:47 AM
Joseph Cissell Joseph Cissell is offline
Was your Dads sale about 60 or 70 miles east of Kansas City. If so, I bought it. I bought two 1905 IHC Verticals that day. Thanks, Joe A.
Old 10-01-2014, 10:48:59 AM
Joseph, A little farther east, Big Springs, Mo. on Hwy 19 ,off Hwy J, in 2001, Gerald Mueller sale, I know a little history on the engine, the cyl had a band around it ,stuck, and poor shape, it would have oil of wintergreen in cyl too,stunk up the whole shed.......I know he only had 1 Famous Verticle too.... Mom couldnt remember where it went , I heard from N Dakota to Ca LOL ....
Old 10-01-2014, 10:49:16 PM
Peter Short Peter Short is offline
That's a nice looking and sounding engine.
Am I correct in thinking the exhaust valve is held open (so the inlet stays closed, because no vacuum in cylinder), then as the governor un-latches, the exhaust rocker is pulled well clear of the valve, giving time for an inlet stroke and ignition....if so, was this a common method of speed control for engines with atmospheric inlets? I haven't seen this before, but then I probably haven't been paying attention!
Old 10-02-2014, 04:44:55 AM
BMiller's Avatar
BMiller BMiller is offline
Peter:
Yes, it's a very nice one. They run so smoothly.
1: yep - ex held open by governor latch
2: yep - governor unlatches, allows pushrod to make a full stroke
3: yep - yes, quite common method. Saved wear on valve gear and ignition, too. Battery powered ones commonly had an interruptoer for the ignition circuit, so that there wasn't battery drain until the moment of firing.
Bill Miller
The Following 2 Users Say Thank You to BMiller For This Post:
Old 10-02-2014, 10:07:38 PM
Tom Fleming Tom Fleming is offline
Great engine. sounds good too.
Old 10-06-2014, 09:25:08 AM
Any IHC experts that can tell me the purpose of the 1/2" hole directly above the oiler that goes into the combustion chamber? Is this hole only on the earlier verticals? Could it be an inspection hole to check if igniter is sparking or a place for a priming cup? When I got the engine it had a 1/2" brass plug with a smaller threaded hole. I didn't have a small enough plug so replaced with a 1/2" steel plug for now.
Old 10-06-2014, 04:45:24 PM
jboyer1028 jboyer1028 is offline
Any idea what the "E" under the serial number means? I have a 1914 Famous 10 hp with an "E" under the serial number.
Jeff
Old 10-06-2014, 06:14:17 PM
I do not know what the "E" stands for, but I have been told 3 different possible meanings--"Export", "Electric", and "Engine." I tend to discount "Export" since there are many early IHC engines in the United States with the "E" suffix. Harry suggested the "Electric" since his 4 HP Famous had a Remy generator and he had seen another with the E that had a Motsinger Auto Sparker. But again, I have seen others including mine that had just battery and coil and still have the "E" suffix. Anybody got an early engine with hot tube ignition? If so, is there an "E" on your serial number plate?
I like the "Engine" idea. I was told that since IHC made many different types of machinery, they used "E" to designate that it was a gas engine. I wonder if other types of IHC machinery used letters on their serial numbers?
1905 IHC 3hp Vertical - Looking for Ideas and Advice Craig Solomonson Hit & Miss Gas Engine Discussion 24 06-17-2019 08:11:27 PM
Bad smoke at startup gomangodave Onan Generators 15 11-20-2011 09:03:16 PM
1/2 HP 1905 Vertical Parsell & Weed Restoration Wayne Grenning Hit & Miss Gas Engine Discussion 27 10-17-2010 10:13:09 AM
Empire 2.5 HP startup SDP Hit & Miss Gas Engine Discussion 3 03-28-2010 09:02:10 AM
Need Parts Diagram for 1905 Vertical Stover Paul Maples Hit & Miss Gas Engine Discussion 2 11-16-2006 09:24:57 AM
