Bendix magneto.
this thread has 3 replies and has been viewed 909 times
Old 02-25-2016, 10:44:35 PM
SteamfanMN SteamfanMN is offline
Default Bendix magneto.
Picked up this "little" beauty today for no reason it is an aircraft style magneto, could anybody give me some more info? Age, what kind of engine or aircraft it was used on? I am providing a picture of the tag for what good it will do as it seems to have no legible marks. How different are these from say a tractor magneto?
ID:	247430   Click image for larger version
Old 02-25-2016, 11:02:59 PM
FWurth's Avatar
FWurth FWurth is offline
One Millionth Post
Images: 4
Default Re: Bendix magneto.
.If it's left hand rotation, it's the same as used on the Allis E tractors. I think any mags used on aircraft would have a armored, water proof cap and cables. That one in the picture is identical to the ones here on the Allis.
Old 02-25-2016, 11:42:44 PM
I turned the coupler but it would only turn to the right which means right hand rotation I'm assuming? Bear with me as I haven't messed around much with mags.
Old 02-26-2016, 03:28:59 AM
matt scott matt scott is offline
Its a Bendix model C4. They were use on Allis tractors for a short time. It probably came off a U,UC tractor or M crawler since it has a stud for a kill wire. They were used on the 34 WC also but had a kill button instead of a stud. I have rebuilt a few of them. Main problem with them (even when they were new) is the coil. I have read that the insulating coating used on the wire would flake off the wire and end up breaking the wire inside the coil. They do have one of the most complex impulse couplings I have seen.
Bendix Scintilla Magneto chzuck Magnetos, Ignition Coils and Spark Plugs 7 07-01-2014 08:52:32 PM
Bendix Scintilla magneto Canadian made Magnetos, Ignition Coils and Spark Plugs 1 10-09-2013 09:18:25 AM
Bendix S-400 Literature Dempster Magnetos, Ignition Coils and Spark Plugs 0 10-09-2012 06:17:05 PM
Bendix-Scintilla Magneto Coil Needed ungerray Magnetos, Ignition Coils and Spark Plugs 12 08-22-2010 10:26:45 AM
Found: Bendix Magneto - Now what? Bruce B. Magnetos, Ignition Coils and Spark Plugs 2 09-26-2007 11:09:05 PM
