Go Back   SmokStak > SmokStak® Antique Engine Community > Small Air Cooled Gasoline Engines > Maytag Engines and Collectibles
Maytag Engines and Collectibles Maytag engines, washing machines, mowers and other engine driven tools for the farm.
Maytag vertical advice
this thread has 2 replies and has been viewed 1319 times
Old 08-12-2010, 05:44:00 PM
Tim Rostar
Default Maytag vertical advice
Im messing with my vertical half horse maytag and i got the carb all fixed and id like to know if my deflooder is suppose to have a check ball in it or if its ok with just being a jet type thing.I need to know the ign timing also .......
Old 08-12-2010, 07:38:46 PM
Tim Rostar
Default Re: maytag vertical advise
hello maytag helpers
Old 08-13-2010, 03:14:07 AM
Mark Shulaw Mark Shulaw is offline
Default Re: Maytag vertical advice
The engines with the type E carb have two different deflooder designs. The earlier one was a jet like thing that had a stip of metal that crossed the face. The strip went from one side to the other held in place by the gasket area. The other was the Gilson deflooder with a check ball like you will see in Ebay item #160466876160 I set my timing to be about 1/4" inch before TDC. You can go somewhat less if you want. Retarding the timing will calm them down but if you intend to put it to work get back towards 1/4" BTDC Mark
The Following User Says Thank You to Mark Shulaw For This Post:
vertical boiler advice Tim Rostar Steam Stationary Engines, Traction Engines 8 10-16-2009 11:29:48 PM
Maytag vertical 1/2 hp mercury dave Maytag Engines and Collectibles 3 11-27-2008 11:13:07 PM
Vertical mill advice Jim Thistle Scale Model Engineering 9 11-01-2008 09:46:51 PM
Early Maytag vertical Rich Hudak Maytag Engines and Collectibles 6 09-14-2008 02:30:40 PM
Maytag vertical crank Dustin D Ehli Hit & Miss Gas Engine Discussion 2 05-02-2007 08:13:58 AM
