Go Back   SmokStak > SmokStak® Shop Equipment Tools and Techniques > Antique Machine Tools (Pre 1930)
Boynton Plummer Shaper
this thread has 3 replies and has been viewed 683 times
Old 04-16-2018, 11:08:02 AM
George Kulisiewicz George Kulisiewicz is offline
Default Boynton Plummer Shaper
This is my Boynton Plummer shaper ... I am in search of a correct flywheel as mine is missing... I believe the shaft is about 1" dia. They made different size models but im not sure if the flywheel was the same on each model or not? Any help would be greatly appreciated. Thanks George
The Following 2 Users Say Thank You to George Kulisiewicz For This Post:
Old 04-16-2018, 12:59:02 PM
Default Re: Boynton Plummer Shaper
If you can get dimensions and photos I could make a pattern for a casting.
Old 04-16-2018, 01:39:51 PM
Hi Mr Bill
Thank you for that offer... that may be an avenue to pursue if I can't find one anywhere... I even thought maybe someone may have one that I can borrow and use to cast one from.
Old 04-16-2018, 06:37:13 PM
Travis McCoy Travis McCoy is offline
Guys,
I took the flywheel off my 6" B&P shaper this evening. Attached are two pictures of the flywheel and my machine. That is an awesome base you have on yours, George. Mine doesn't have an original base, but is instead mounted on part of an old cream separator.
Here are the flywheel measurements:
Diameter: 14"
Rim: 1-3/16" Thick X 1-5/16" Wide
Center hole: 1"
Hub Dia: 2-1/8"
Hub Overall Length: 2-1/2"
Hub length from spokes (edge, not center) 1-1/8" on one side, 5/8" on the other
Spokes: Serpentine shape, 3/4" wide at rim, 1-1/8" at hub, thickness 1/2"
These are all approximately close with a tape measure. You wouldn't necessarily need serpentine spokes on the flywheel, but gosh they look sweet.
Hope this helps gents, and glad that Harry added this category to the forums.
Thanks!
Travis
ID:	308409   Click image for larger version
ID:	308410   Click image for larger version
The Following 2 Users Say Thank You to Travis McCoy For This Post:
New Toy, 8 Inch Shaper Tanner Remillard Machine Shop and Tool Talk 11 10-29-2017 02:55:21 PM
Shaper for sale Alastair Geddes. Machine Shop and Tool Talk 0 04-14-2015 06:40:48 AM
Metal Shaper bigbearblacksmith Machine Shop and Tool Talk 21 02-16-2013 02:45:02 PM
Old Shaper Junkologist Machine Shop and Tool Talk 4 10-04-2006 01:03:41 PM
