TORO Eiseman 71t
this thread has 3 replies and has been viewed 1013 times
Old 08-21-2015, 09:12:12 PM
ELIDAS ELIDAS is offline
Photo TORO Eiseman 71t
I have a Toro engine with a dead Eiseman 71t. I pulled the flywheel tonight and found the inside covered with some kind of crud. Almost like it has melted plastic all over it. This is contained only inside the mag assembly and the inside of the flywheel. I'm not sure what to make of it. Normal?
Old 08-21-2015, 10:02:25 PM
Default Re: TORO Eiseman 71t
Looks like compressed baked organic material infused with oil seepage and exposed to a lot of engine heat. Basically crud. Might try oven cleaner on it.
Doc
Old 08-26-2015, 10:04:04 AM
naylorbros naylorbros is offline
Chances are the coil is cooked. They leak that nasty goo when they are going bad.
Ken
Old 08-27-2015, 03:00:37 AM
cobbadog cobbadog is offline
For my 2 cents worth the mess has come from outside of the magneto area and not the coil. If it was from the coil the mess would have started at the coil and dripped downwards from there. There is evidence that the mess has come in from that joint in the alloy housing, possibly oil spillage or a leak. Clean it up using a degreaser and try again. Protect your coil from the degreaser and water as much as possible just to be on the safe side.
EISEMAN MA1 coil wanted. caporal30 Chain Saw Collectors 3 02-19-2012 05:57:47 PM
Eiseman G4 edition 3 Jim Ryan Magnetos, Ignition Coils and Spark Plugs 4 10-28-2009 10:43:45 PM
Eiseman mag slug Magnetos, Ignition Coils and Spark Plugs 1 02-29-2008 09:39:02 AM
Eiseman CM-4 mag Tanner Remillard Antique Engine Archives 1 01-25-2003 03:22:21 AM
Help on Eiseman Mags C H Hobrat Generators & Electric Motors General Discussion 0 11-05-2001 07:32:16 PM
