AB magneto kill switch
this thread has 1 replies and has been viewed 1155 times
Old 09-27-2015, 07:51:54 PM
dlp dlp is offline
Default AB magneto kill switch
I have a zr-4 & I need the kill switch that is mounted in the point cover. Is anyone making these parts? Thanks in advance!
Old 10-05-2015, 11:18:40 AM
Default Re: AB magneto kill switch
Check the sponsors page here on the Stak - marks and others may have what you need. If necessary, you can make your own out of either a bit of spring copper or a strip of steel. If your internal bits are gone, then they will have to be made. Check with the mag guys first!
Maytag 72d kill switch? Whozawhat Maytag Engines and Collectibles 6 02-20-2013 12:54:03 PM
Kill Switch Jim Alexander Hit & Miss Gas Engine Discussion 2 11-10-2012 08:18:22 PM
Wisconsin TFD - Kill Switch bondoo0 Wisconsin Engines 9 03-28-2011 06:41:43 AM
Wisconsin TFD - Kill Switch bondoo0 Wisconsin Engines 0 04-06-2010 12:14:58 PM
Caution Plate & Kill Switch blake in spokane Maytag Engines and Collectibles 1 10-16-2008 10:58:55 PM
