4 hp Sparta w/ Lukenheimer
this thread has 3 replies and has been viewed 901 times
Old 08-11-2017, 01:49:15 PM
HitnMiss Todd HitnMiss Todd is offline
Default 4 hp Sparta w/ Lukenheimer
I am having problems getting the engine to start and keep running. First problem is the fuel fitting to the mixer. What is the proper fitting for the fuel inlet? It looks like this is a grease cup that was threaded on and a hose slipped over it and then clamped. It does not seal very well and fuel will leak out. If it's leaking I am sure air is entering. When it does start it will only run a few seconds before it starts to die. It did have a check valve at the tank but I removed that per other threads I found on the Stak. No change to the starting or running.
Old 08-11-2017, 06:05:33 PM
J Eddy's Avatar
J Eddy J Eddy is offline
Default Re: 4 hp Sparta w/ Lukenheimer
Most Lunkenheimer carbs require the fuel tank to be above the carb. The Vaccum valve in carb needs to seal well to keep gas from leaking thru between charges.
The Following User Says Thank You to J Eddy For This Post:
Old 08-11-2017, 07:35:05 PM
This fuel tank is in the base of the engine and the Lunk is close to the same level. In other words, the fuel line is almost level from the bottom of the tank to the inlet of the Lunk.
Old 09-01-2017, 12:41:49 AM
https://goo.gl/images/CZgZWd
Lukenheimer on a model Red Wing Tom Jamboretz Carburetors, Mixers, Fuel Pumps and fuel delivery 6 05-18-2016 09:25:56 AM
Lukenheimer Oiler MarkBillesbach Hit & Miss Gas Engine Discussion 6 03-09-2009 09:17:00 PM
Lukenheimer carb question flasks Hit & Miss Gas Engine Discussion 4 01-01-2009 11:52:23 AM
Lukenheimer Oilers Greg-N-CA Hit & Miss Gas Engine Discussion 3 11-01-2008 02:28:25 PM
LUKENHEIMER TOO RICH TOO LEAN? Johnboy Antique Engine Archives 4 06-22-2003 11:15:21 AM
