Aluminum adhesive
this thread has 13 replies and has been viewed 2543 times
Old 06-10-2014, 09:29:09 PM
Reed K Reed K is offline
Default Aluminum adhesive
What would be the best adhesive to bond two pieces of aluminum. Need something that can take a lot of vibration and stress.
Old 06-10-2014, 10:18:09 PM
Default Re: Aluminum adhesive
The urethane adhesive that they use to glue windshields in is very tough, may require a primer.
Old 06-11-2014, 03:29:07 AM
Best way depends alot on thickness and size of aluminum to be bonded.
There's http://www.hotmelt.com/products/alum...FQaBfgodexcAQA epoxy.
There is spot welding... (only for thin stuff and requires small steel inserts between copper tips and aluminum.)
Last is an odd one: Soldering. Requires removal of oxide surface. One trick is to apply a drop of light oil to surface to keep it from rapidly oxidizing while you tin it. Solder right through the oil to tin both sides of the joint. Tinning then prevents the rapid oxidation so you can sweat solder the surfaces together. I've also seen urethane epoxy, but it is very pricey.
Doc
---------- Post added at 01:29 AM ---------- Previous post was at 01:25 AM ----------
Oh... after applying oil, you need to remove oxide with an abrassive or wire brush. Reading back I see I missed that part. Was blown away the first time a friend showed me how to solder a wire to a sheet of aluminum.
The Following 2 Users Say Thank You to Thaumaturge For This Post:
Old 06-11-2014, 10:10:42 AM
kwfiggatt kwfiggatt is offline
Wow - the soldering aluminum info is neat. What kind of flux and what kind of solder? Ordinary 50/50 solder and plumbing flux? Or, do you even need the flux, since you are protecting the surface with the oil?
Thanks,
Kevin
Old 06-11-2014, 01:54:18 PM
kwf, brazing aluminum is very tricky and difficult to do manually until you learn all the nuances. I have provided numerous automated aluminum brazing systems to Ford, GM, and Chrysler all for brazing tubes and fittings to air conditioning condensers and other components.
The problem is essentially that the brazing alloy melts 100-150 degrees below the parent metal therefore requires precise attention to controlling the heat.
You can't use convention lead/tin/antimony/silver solder or brazing alloys or conventional fluxes. The alloy is a discreet aluminum composition and has to be used with a dedicated aluminum flux. This typically is called Nocalox.
Cleanliness is more important than anything you've ever brazed, and using a torch typically introduces contaminates that make a crappy joint.
As to bonding with adhesive, look at 3M, Fusor, and Lord adhesives. They are the major suppliers to automotive. Note that these good adhesives are heat cure and need over 180F to crosslink and set up.
Old 06-11-2014, 06:48:44 PM
First off I'm talking about light gauge aluminum and a fairly small joint area. I've used regular rosin core 60/40 electronics solder. The purpose of the oil is strictly to keep the oxygen away from the aluminum surface once the aluminum oxide is removed. Aluminum oxide is chemically identical to Saphire. Aluminum is what is referred to as a self healing metal. The reason it doesn't corrode is because any scratch through the surface oxide will very rapidly oxidize again. The aluminum oxide then prevents any further oxidation. So the oil blocks the oxidation while you TIN the desired area with a lead/tin coating, which also blocks oxidation. After entire area of both sides of the joint are tinned, they can then be clamped together and sweat soldered by application of sufficient heat for both tinned areas to melt. There are aluminum solders available, but I've never had much luck with them. I can see brazing would be another thing entirely, as "I Like Old Things" suggested. Very tricky.
But you haven't as yet specified the gauge of the aluminum or the size of the joint. Such may be beyond my suggested method.
Doc
Old 06-12-2014, 10:45:10 AM
I have had good results with Harbor Freights aluminum brazing rods.
Clean the metal till it shines.
heat with propane torch
scratch rod all over surface to be joined.
The stuff melts around 700*F
The Following User Says Thank You to sdowney717 For This Post:
Old 06-12-2014, 12:09:48 PM
ChipTosser ChipTosser is offline
Can you give us an example of what you are wanting to bond with an adhesive?
What and how is this going to be used? The weight, size of flat, flange area lenght.
Is it being exposed to oils, fuels?
There area number of good adhesives, just need more information on how what the requirements are.
Old 06-12-2014, 01:33:44 PM
It is a flange 1/2 x 1 Inches that needs to be attached to the bottom side of a cast aluminum carburetor. The flange will have a bracket bolted to it with a approx weight of 2 lbs. The only bonding compound I am familiar with is JB weld. Thanks in advance for the help!
Old 06-12-2014, 01:49:33 PM
Have you considered fabbing a bracket from another area? Mounting to a carb could be inviting trouble.
Old 06-12-2014, 01:55:11 PM
A carb is pot metal, the HF rods will still work, just do not overheat the base because it will suddenly let loose, it will sludge then liquify. You must be careful with pot metal repairs.
You can get a lower temp rod from Muggy weld which melts at 350* F.
http://muggyweld.com/pot-metal-repair
HF rods
http://www.harborfreight.com/8-piece...ods-44810.html
Old 06-12-2014, 09:15:09 PM
JBweld was good stuff for gasoline exposure but not anymore due to E10.
It turns brown and cracks and crumbles off aluminum.
I tried it in 3 different apps with carbs and all failed.
One was bottom well sealing of Rochestor 4MV.
Two was cracked fuel tank aluminum top Briggs lawnmower
Three was old aluminum model B Brigs carb flange top where throttle shaft is bored.
Eventually it softens and cracks and you can peel it off with your fingers.
Old 06-12-2014, 11:40:49 PM
pjjms pjjms is offline
Brazing the bottom of a carb is for the experienced. Talk to your local RV shop, they bond cladding all the time. 2lb may be a stretch though.
The Following User Says Thank You to pjjms For This Post:
Old 06-13-2014, 12:56:23 AM
gootsch gootsch is offline
I used to get from NAPA something called Cold Weld Compound made by Loctite as I remember. I bonded to aluminum and other metals with no problems. We even fixed a crack between two cylinders in an AC tractor with it and a crack in the water jacket deep within the vee of an 8V92 Detroit Diesel, it lasted for years until the truck caught fire and burn to a crisp.
The Following User Says Thank You to gootsch For This Post:
Is This Mower Aluminum? wheelhorseman Garden Tractors and Mowers 3 11-22-2009 11:09:47 AM
Elecrolysis & Aluminum Rex Piekarczyk Machine Shop and Tool Talk 1 10-15-2008 07:45:16 PM
Aluminum piston, aluminum cylinder? NAR Scale Model Engineering 9 03-11-2008 02:02:27 AM
Aluminum I.D. Tags Sky Hit & Miss Gas Engine Discussion 1 03-29-2005 09:30:58 AM
aluminum help mike Antique Engine Archives 10 02-07-2001 06:14:57 PM
