801 Ford powermaster 4 cyl
this thread has 7 replies and has been viewed 3289 times
Old 10-07-2014, 04:03:33 PM
glennponnath glennponnath is offline
Default 801 Ford powermaster 4 cyl
I am wondering whats wrong.. I start up my 4 cyl ford 801 powermaster with absolutely no problems.. The fan belt broke off so I purchased a new fan belt with goes around the fan (of course), the waterpump pulley at the bottom of engine. and the alternator.. Now the problem occurs.. I start the engine and it instantly Rev's super high and stays at that high rev.. naturally I have to shut down the tractor almost instantly..
Any ideas?
Glenn
Old 10-07-2014, 04:08:42 PM
Default Re: 801 Ford powermaster 4 cyl
Sounds like something in the governor mechanism locked up and snapped the belt and the new 1 is just strong enough that it has not broke yet.
Old 10-07-2014, 07:01:20 PM
But why when I take the belt back off the tractor revs correctly?
---------- Post added at 06:01 PM ---------- Previous post was at 05:48 PM ----------
additional:
When I take the belt back off the tractor returns to normal rev..
Old 10-07-2014, 08:55:49 PM
Kris Golden Kris Golden is offline
Your belt routing must be hitting the governor linkage. Try to run the belt on the other side of the linkage. ???
The Following User Says Thank You to Kris Golden For This Post:
Old 10-07-2014, 11:52:36 PM
I will try that.. thanks... but i dont think its around anything except the pulleys.. but I will look
Old 10-09-2014, 10:51:20 PM
No the belt is fine.. Nowhere near the linkage..
let me reword my problem.. I have a 4 cyl ford 801 gas powermaster that the fan belt broke off somewhere and somewhen ..
it starts just find except it over heats quickly due to the water pump not running due to the fan belt..
now I put the new belt on and start it up and it rev's up very high and keeps the revs up high.. I even tried turning the throttle way way down.
when i take the belt back off and start the tractor, strangely it runs just fine.. no high revs..
Put the belt back on and high revs again..
Anybody?
Thanks..
P.S I am a complete noob when it comes to working on tractors..
soo.. where is the governor again? stupid question I know..
Old 10-10-2014, 12:43:05 AM
Klicknative Klicknative is offline
The governor is inside the front cover with the flyweights on the crankshaft in front of the timing gear. Make sure the crank pulley bolt is tight and the pulley is tight on the crankshaft. Does it leak oil out of the front main seal?
Old 10-10-2014, 10:10:46 AM
RSCurtis RSCurtis is offline
Could it be that it's always running too fast but the noise of the fan when it's turning is what you're hearing?
1958 Ford 841 Powermaster Ryan Anderson Antique Farm Tractors 25 05-21-2014 09:45:06 AM
1934 Sears And Robuck Powermaster 1000 Mr Ed Generac Generators (SEARS, etc.) 1 11-27-2012 12:36:18 PM
Sears Powermaster Generator WVCS1958 Generac Generators (SEARS, etc.) 1 02-10-2012 05:57:50 PM
Powermaster Charger Model 2104 LordStoneWolf Generators & Electric Motors General Discussion 2 11-08-2011 10:39:00 PM
Powermaster Generator WVCS1958 Generators & Electric Motors General Discussion 3 05-03-2009 08:59:23 PM
