B&S 130902 001 gov spring diagram
this thread has 1 replies and has been viewed 1247 times
Old 12-12-2014, 08:24:42 PM
doug9694 doug9694 is offline
Default B&S 130902 001 gov spring diagram
I would like to have a pic or pdf source that shows where the small spring on the gov. link to the throttle goes. There is a short arm with a hole and a longer where the link goes. Does the spring go in with the link or in the shorter arm? Same with the other end. I have the link and spring going into the outer hole. There is another hole in the side of the gov. arm. Anything go there?
Old 12-15-2014, 10:59:22 PM
jcarter jcarter is offline
Default Re: B&S 130902 001 gov spring diagram
Do you have the code for the engine? I can email you the shop manual for your engine.
Must be spring! Sekiar Hit & Miss Gas Engine Discussion 2 03-30-2014 08:41:54 PM
spring dia.? Jon Mrozinski Hit & Miss Gas Engine Discussion 0 08-27-2012 12:02:23 AM
Spring is on its Way! Farquharman Steam Stationary Engines, Traction Engines 2 12-21-2010 10:04:09 PM
