Smokstak Down Under
Lister J and L fuel tank
this thread has 2 replies and has been viewed 1105 times
Old 06-27-2015, 08:29:16 PM
P Grogan P Grogan is offline
Default Lister J and L fuel tank
hi all I'm looking for fittings for lister j and l fuel tanks
Can anyone help? Digger 0487200137
Old 06-30-2015, 07:14:15 PM
cobbadog cobbadog is offline
Default Re: Lister J and L fuel tank
By fittings do you mean the threaded pieces if so contact John on this email
sumron@southernphone.com.au
John makes tanks and should be able to supply you with the parts you need. Also try Pirtek for some of those parts as they sometimes do have the parts.
Old 07-01-2015, 02:14:55 AM
john gilbert john gilbert is offline
Hi P Grogan I have sent you a personal message, cheers, John
The Following User Says Thank You to john gilbert For This Post:
Lister Type R fuel tank eastcoaster Hit & Miss Gas Engine Discussion 1 01-03-2015 05:23:10 AM
Early Lister D fuel tank and mounting bracket robert hamilton Smokstak Down Under 0 02-09-2013 07:37:25 AM
Fuel tank - desolder tank halves to repair? KD5BYB Small Air Cooled Gasoline Engines 8 12-04-2011 06:08:58 PM
2-71 loss of fuel pressure from fuel tank-check valve? or bad fuel pump? Walter J. Generators & Electric Motors General Discussion 18 08-24-2011 09:22:40 AM
Tank capacity, Lister J?? B. K. Lahey Vintage Diesel and Oil Stationary Engines 7 06-30-2006 11:22:57 AM
