Wico c help!
this thread has 2 replies and has been viewed 1020 times
Old 08-21-2015, 08:44:48 PM
Matt1931 Matt1931 is offline
Email Not Working
Default Wico c help!
It's on a 1936 Jd br and I don't think it's hot enough. I put a screwdriver in the coil wire hole and put it about a 1/8th in away from my work bench ( that I also had my leg against.) And I turned it past impulse and bam! ⚡️Spark at screwdriver - 3 of my fingers holding the base and my leg. So do I have a small short going to the base? So I started to take it apart and impulse nut was finger tight. So I removed it and spring unwound, so now what? How many times do I wind it? Anything to look for? Spark is blue but small at plug
Old 08-22-2015, 01:39:05 PM
Default Re: Wico c help!
You might need a magnet recharge. As for the spring, I have no experience with it, sorry.
Old 08-23-2015, 01:44:31 PM
mmcdonald mmcdonald is offline
Banner Sponsor
The spark generated at the coil output is trying to find it's way to ground(which in this case is the magneto housing). Evidentially the best electrical path in this scenario for that was through your body. Spring needs half a turn of pre-wind after you wind it enough to fit the drive plate. Make sure the spring ends are fit in the drive washer on shaft and in drive cup. Turn cup CCW enough so that it can be installed then 1/2 turn additional and install). If it hasn't been done recently a magnet charge as suggested would be a good idea(needs to be done when you will no longer be removing the coil as this weakens the magnet every time you have it out). Also highly possible coil or condenser is causing problems. Should jump 1/4" spark gap minimum consistently. I have had a lot of people over the years tell me mag is hot because it shocked them. You will feel a "good jolt" at far below what that mag needs to do to run the engine.
info@mcdonaldcarb.com
Wico XH mag AugerCreek Magnetos, Ignition Coils and Spark Plugs 5 08-22-2013 03:13:11 PM
Wico MO1 GeneratorGus Hit & Miss Gas Engine Discussion 0 05-08-2013 07:50:08 AM
wico ek randi strunk Magnetos, Ignition Coils and Spark Plugs 2 07-30-2009 08:30:16 PM
Wico mag Dave Ho Antique Engine Archives 3 01-21-2003 11:34:28 AM
$10 Wico's where are they??? Adam Cottrill Antique Engine Archives 3 10-22-2002 12:13:18 PM
