john deere igniter adjusting point gap
this thread has 2 replies and has been viewed 1443 times
Old 08-28-2015, 08:41:44 AM
nita200 nita200 is offline
Default john deere igniter adjusting point gap
I have a John Deere 1 1/2 hp hit and miss engine that is ready to run except the points don't open 1/32nd inch when I hand trip the anvil. Does this sound like a worn part on the igniter? I need some help. Thanks
Old 08-29-2015, 12:19:08 PM
mmcdonald mmcdonald is offline
Banner Sponsor
Default Re: john deere igniter adjusting point gap
If you push the anvil opposite the way the trip lever pushes it the points should open a good bit, like 3/16" or something along those lines. I don't' have one in front of me at the moment. If something "hits" before they open much then either it is put together wrong or there is wear as stated. If they do open that much then either there is too much friction on the moving parts from rust or such or the torsion spring may be weak.
info@mcdonaldcarb.com
The Following User Says Thank You to mmcdonald For This Post:
Old 09-12-2015, 12:06:56 AM
Thanks McDonald I replaced the old anvil with a new one which is adjustable and now the points work. nita 200
John Deere 40C. Adjusting throttle control link from governor to cab. crawfish Farm Antiques and Collectibles 1 06-17-2013 08:38:40 PM
John Deere B with factory 3 point Tim Dittmer Antique Farm Tractors 7 01-30-2010 12:06:42 PM
Adjusting John Deere 2btm plow ssimntih Antique Farm Tractors 1 01-09-2010 02:31:06 PM
John deere 3 point for a 1949 model A The motor kid pig guy Antique Farm Tractors 3 12-13-2009 08:16:18 PM
John Deere E igniter steve hales Hit & Miss Gas Engine Discussion 6 11-17-2008 12:33:07 PM
