bad buzz coil....HELP
this thread has 7 replies and has been viewed 1380 times
Old 09-04-2015, 05:48:36 PM
HitMiss196 HitMiss196 is offline
Default bad buzz coil....HELP
I have a 1HP Tom Thumb I am trying to get running. It has been sitting for 20+ years. When I put a new battery in it and tried to get the buzz coil to fire it wouldn't. I found a procedure to check the coil for ohms. On the secondary windings I get 3100 ohms as it appears I should. However when I check positive post to the spark plug post I'm suppose to read the same and is wrong. Only 1,200 ohms. From negative post to spark plug post (primary windings) I'm suppose to read only about 43 ohms however I get about 1,200 ohms. I have never attempted a repair of a buzz coil though I know it can be done. Looking for any help for me to repair my buzz coil. As much information on this would be greatly appreciated. Thanks.
Old 09-04-2015, 06:26:34 PM
David Hughes David Hughes is offline
Default Re: bad buzz coil....HELP
Are the points clean?
I understand it is common for the condensor to be dead. I understand you can hook up a modern automotive condensor between the points to bring them back to life
Old 09-04-2015, 07:50:30 PM
Alan R Alan R is offline
Are you trying to fire it through the engine or just between battery and coil? If trying to go through the engine it may not be the coil. Brush top and bottom contacts with leads and see if it sings.
Old 09-04-2015, 08:04:07 PM
Most common cause of high resistance is at the screws. Disassemble the top, clean the points, if you have a bead blaster blast everything that has to make contact, sand and brush everything if you don't have a blaster. spray with a penetrant, assemble and test.
Old 09-04-2015, 08:57:53 PM
Ok I'll try and clean it up and see.....thanks
Old 09-04-2015, 09:10:45 PM
Steve Kreiner's Avatar
Steve Kreiner Steve Kreiner is offline
If you are having problems with it I just live over the hill in Norwich Contact me 607 334 8764
Old 09-05-2015, 05:02:05 AM
Wow that would be great....I will contact you afterthe long weekend. Thanks Steve
Old 09-10-2015, 12:56:55 AM
Thanks again for all the help with my coil problem. After a good blasting in the glass cabinet it worked like a champ! I got the TT running today. Sure was music to my ears. I tried to upload a video but I couldn't get it to go. I have the video on a Hit and Miss Faceook page. Thanks again everyone.
Rick
How to hook Detroit Coil Co buzz coil - pics Prowl1 Magnetos, Ignition Coils and Spark Plugs 9 04-06-2015 12:09:22 AM
Model T coil or Buzz coil Jerry B Magnetos, Ignition Coils and Spark Plugs 2 11-12-2010 10:41:01 AM
Buzz coil vs. auto coil. Jeremy Hartle Magnetos, Ignition Coils and Spark Plugs 5 12-11-2009 11:50:21 AM
Buzz coil or auto coil Don Nelson Antique Engine Archives 5 12-07-2004 06:08:54 AM
BUZZ COIL A.J. TELOWICZ Antique Engine Archives 5 01-16-2003 12:40:35 PM
