Novo Rollr with wrong Mag
this thread has 0 replies and has been viewed 1002 times
Old 09-23-2015, 09:23:01 PM
beeks beeks is offline
Default Novo Rollr with wrong Mag
I have a parallel twin cylinder Novo that I picked up without a magneto. I picked up a Fairbanks Morse mag that I believe came off a v4 Wisconsin engine. The Novo fires the second cylinder 270 degrees after the first. Should be the same degrees as the two front or rear cylinders of the Wisconsin V4. I'm thinking about driving it with a bicycle chain and sprockets.
That bring me to my question. The mag is a flange mount with a gear on it that I'm sure ran in oil. Does the mag bearings use oil for lubrication?
Novo Rollr KU 3 X 4 Gary Bahre Hit & Miss Gas Engine Discussion 3 12-24-2015 08:18:35 PM
Novo Rollr TU parts advice needed Zira Hit & Miss Gas Engine Discussion 2 08-14-2014 08:47:30 AM
Novo Rollr parts? beeks Unidentified Engines 7 01-07-2014 12:26:58 AM
Novo Rollr Engines SMertz Hit & Miss Gas Engine Discussion 10 03-13-2010 09:14:29 AM
Novo RollR Bill Antique Engine Archives 5 08-12-2003 10:44:09 PM
