B&s WI motor
this thread has 11 replies and has been viewed 1125 times
Old 10-12-2015, 05:11:02 PM
Geochurchi Geochurchi is offline
Location: Bartlett, New Hampshire, USA / Toronto, Ontario, Canada
Default B&s WI motor
Hi All,can't get this motor to start,there is a decent spark,fresh gas,carb is clean and adjusted to the spec,needle valve out 1 turn,I can see gas in the throat of the carb so gas is being picked up from the tank.
Any thoughts?
Geo
Old 10-12-2015, 05:13:29 PM
Bolens 1000 Bolens 1000 is offline
Default Re: B&s wi motor
To rule out the carb as an issue will it fire and run a few seconds if you pour some gas down the plug hole ?
Old 10-12-2015, 08:37:53 PM
No,but I wasn't sure how much gas to pour in there, I tried some starting fluid but that didn't do the trick either,I do have a spark when I lay the plug on the head.
Geo
Old 10-12-2015, 09:36:46 PM
Just because you see spark out of the cylinder does not mean its strong enough to produce a spark while under compression, do you have an inline spark tester so you can see if your getting a strong enough spark to fire?
The engine should start right up with a little squirt of gas or a shot of carb cleaner down the plug hole.
Old 10-13-2015, 07:35:18 AM
I'll get one, I wasn't thinking about the spark under compression ,what is the correct way to test the compression?this is my first time trying to restore a motor this old so we will see what happens.
Geo
Old 10-13-2015, 08:03:04 AM
Mason R Mason R is offline
Default Re: B&s WI motor
You might also have a bad Sparkplug
Old 10-13-2015, 09:13:20 AM
Just an idea, perhaps it's weak magnets that won't produce spark under compression. For a test try closing the points gap down to about .008 to give it more dwell time.
Old 10-13-2015, 08:33:43 PM
Have not seen the motor run,picked it up an an engine show for something to try and restore,it does have compression and a new J8 plug, I have ordered an inline spark plug tester to see if I can tell what's going on.
Going to be awhile before I get to that.
Geo
Old 10-13-2015, 10:14:50 PM
Grape Grape is offline
Ditto on what Akuna said. Find the top of the compression stroke. Mark the top of the flywheel with piston at top of compression stroke. turn it over fast enough to see spark at the plug. If the timing is close you may be able to see the mark you made at about the time the plug sparks. If not then timing is wayyyy off. This is just a diagnostic test not to be used to time exactly.
Even a partially sheared flywheel key can move timing enough to prevent starting.
Good luck.
Phil Grape
Remember, to Belittle others is to Be Little yourself
Old 10-14-2015, 08:43:06 AM
Wouldn't it be better to check the marks on the gears to see if it is set right? I did at one point after pouring gas in the cylinder get a few puffs of white smoke,key seems to be tight in the flywheel,no muffler installed but I doubt that should affect anything.
Who ever had this before did drain the gas as the tank and carb are clean although the throttle shaft has a little play.
Geo
Old 10-14-2015, 02:07:02 PM
Yes, it would be better but I was assuming you wanted to test as much as possible before opening it up. Good luck
Phil Grape
Old 10-15-2015, 04:37:48 PM
But now that I think about it that is valve timing,I believe.
Geo
How will the uF of an AC induction motor capacitor affect the torque of the motor? realflow100 Generators & Electric Motors General Discussion 6 05-27-2015 01:21:35 PM
Westinghouse 1.5 induction motor help (compressor motor) eeprete Generators & Electric Motors General Discussion 20 10-30-2014 04:41:22 PM
Motor Brushes for a Vintage Motor Twincreek Generators & Electric Motors General Discussion 4 11-08-2011 01:07:07 AM
need help to id motor D Shepp Small Air Cooled Gasoline Engines 2 04-14-2007 07:23:56 PM
AC or DC motor Myron Reiss Generators & Electric Motors General Discussion 1 10-17-2001 02:14:37 AM
