Ignitor & Bracket ID Needed
this thread has 3 replies and has been viewed 915 times
Old 10-25-2015, 07:05:34 AM
OzzieHawker OzzieHawker is offline
Photo Ignitor & Bracket ID Needed
Hi, Can anyone identify what engine this ignitor & bracket is used on? Thanks.
ID:	237438   Click image for larger version
ID:	237439   Click image for larger version
ID:	237440   Click image for larger version
Old 10-25-2015, 10:28:44 AM
Bryant Bryant is offline
Default Re: Ignitor & Bracket ID Needed
maybe IHC famous 4 6 8 10 hp? looks like the roller for the trip is broke off.
The Following User Says Thank You to Bryant For This Post:
Old 10-25-2015, 10:44:38 AM
Pat Barrett Pat Barrett is online now
Sometimes the bracket no. is on the bracket under the mag. Spray some penetrant on the mag studs and nuts and get it off the bracket and check for a no. there. I agree, it looks I.H.
The Following User Says Thank You to Pat Barrett For This Post:
Old 10-26-2015, 02:42:58 AM
Hi, Yeah had small thought that it was IHC mag & bracket - I took the pics on the run with no time to remove mag - the mag is a hundred mile from me but will get my mate to remove mag & get the serial number - if memory serves me right should the famous/ih bracket serial usually start with a 3? I don't own a famous but wish I did!! Thanks
Ignitor and mag bracket ID help Swanstone Hit & Miss Gas Engine Discussion 3 12-28-2013 11:10:42 PM
Webster Ignitor Bracket ID Needed Jason Dahm Hit & Miss Gas Engine Discussion 2 10-20-2011 10:29:16 PM
Ignitor Bracket ID Needed Mike Monnier Hit & Miss Gas Engine Discussion 9 01-18-2011 11:01:47 PM
Unknown Ignitor Bracket Maytag Magnetos, Ignition Coils and Spark Plugs 4 12-07-2009 10:33:16 PM
Ignitor bracket ID help... Monkry Hit & Miss Gas Engine Discussion 3 03-07-2005 12:36:14 AM
