1 3/4 Monarch
this thread has 3 replies and has been viewed 930 times
Old 11-08-2015, 01:02:50 PM
Sawmill7 Sawmill7 is offline
Default 1 3/4 Monarch
Can someone tell me or show a pic of how the exhaust rod is held in the rear position on a 1 3/4 Monarch gas engine. It has a rectangle push rod for exhaust rod but now where I can see to hook a spring unless mine is missing. Thanks for any help
Old 11-08-2015, 02:19:10 PM
Bob Naske's Avatar
Bob Naske Bob Naske is offline
Default Re: 1 3/4 Monarch
That is probably a Nelson Bros built engine in which case it would have a large diameter spring outside of the exhaust valve spring that stayed in contact with the "paddle " style exhaust rocker arm thereby pushing the exhaust pushrod back.
Fixing old engines-the pay ain't much but the goodtimes are priceless.
Old 11-08-2015, 08:22:31 PM
Thanks for the reply. It does have the paddle style exhaust arm.
Old 11-12-2015, 02:58:00 PM
Odin Odin is offline
Most of the nelson built engines I've encountered including my own T 1 3/4 jumbo have a rectangular pushrod with a rounded end that passes through a ring in the top of the mixer/carburetor.
The return spring goes between that ring and the shoulder in the rod where it goes from rectangular to round.
Take care when selecting a spring to put here that the engine never ever bottoms it out- if you can't see gaps between the coils of the spring, its too long. On my engine the ring on the mixer was broken off by too long of a spring, I had to braze it back on. Today the engine runs with a stack of shims on the rod to adjust the return force, that way I don't risk breaking it again.
Monarch 30-20 and 30-18 Joe P Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 10-22-2012 01:09:07 PM
Monarch Help oldironcollector Hit & Miss Gas Engine Discussion 4 11-06-2011 07:44:28 PM
Monarch 12 hp gen set Mark Mueller Vintage Diesel and Oil Stationary Engines 1 11-02-2009 03:20:45 AM
3HP Monarch Tom Winland Antique Engine Archives 0 09-29-2003 09:37:58 AM
7hp Monarch mike otis Antique Engine Archives 2 06-04-2001 07:30:18 PM
