Are cork float/needle for B&S Model A early type carbs available?
this thread has 2 replies and has been viewed 943 times
Old 04-08-2016, 08:17:53 AM
johnnyrock70 johnnyrock70 is offline
Default Are cork float/needle for B&S Model A early type carbs available?
Hi all,
I've been putting it off, but really need to track one down.
Are replacement floats available for the early style carb on the Briggs Model A's available?? Mine is a 1934 model year.
thanks
Old 04-08-2016, 09:36:48 AM
ehpower2's Avatar
ehpower2 ehpower2 is offline
Default Re: are cork float/needle for B&S Model A early type carbs available??
If you can not find them the outboard guys do this all the time. Most of the outboard i know of from around the same vintage used cork for carb floats if you go to the hard ware store they usually have cork stoppers, we then just sand them down and seal them up with super glue. That then will become a new carb float that works perfectly.
Old 04-08-2016, 09:40:15 AM
bigGURN's Avatar
bigGURN bigGURN is offline
You can also seal them with gas tank sealer, like Red Kote. We have to do this often on early two man chainsaws where the cork is damaged or missing. Works well. With all the Ethanol now, I have started to coat even pristine floats to avoid damage!
Mall model 8 Cork float? Should I gas it up? A S Price Chain Saw Collectors 18 01-18-2013 07:30:11 PM
Suction VS Float type carbs Bigjoedo Small Air Cooled Gasoline Engines 4 10-21-2011 08:59:01 PM
Resealing a cork float? Peter Ruffle Small Air Cooled Gasoline Engines 5 07-27-2009 05:10:45 PM
cork float larry harding Antique Engine Archives 3 07-28-2004 08:30:17 PM
sealing a cork float Kelly Antique Engine Archives 5 07-25-2001 01:40:05 AM
