Best or Holt carb?
this thread has 6 replies and has been viewed 986 times
Old 05-30-2016, 02:22:05 PM
5hpGalloway 5hpGalloway is offline
Default Best or Holt carb?
Not sure but i think its off a best tractor? Any help would be great
ID:	255111   Click image for larger version
ID:	255112   Click image for larger version
ID:	255113   Click image for larger version
Old 06-01-2016, 07:43:33 PM
Default Re: Best or Holt carb?
Well i gess i should look for info/confirmation in the lugs and cleats???? Maybe
Old 06-01-2016, 07:50:59 PM
flywheelphil flywheelphil is offline
If I remember right Best used Ensign and Holt used Scheblers.
The Following User Says Thank You to flywheelphil For This Post:
Old 06-01-2016, 10:51:31 PM
carbking carbking is offline
The information I have is that Best used primarily Ensign type Gte carbs, which your carb appears to be. However, other companies also used the Ensign Gte, so this is not positive proof.
As to Holt, my information shows Holt used mostly Kingston carbs.
Jon.
The Following User Says Thank You to carbking For This Post:
Old 06-01-2016, 11:24:21 PM
Les Layton Les Layton is offline
I have one on a Harris combine engine 45hp I think Les
The Following User Says Thank You to Les Layton For This Post:
Old 06-02-2016, 12:31:49 AM
Thats great to know! I have had this carb sitting on a shelf for a while in the shop saw a video with a best crawler and it had what looked to be this carb on it . That made me wonder if this is a stock carb for one of those two crawlers but it seems this carb is used on more then just them.
Old 06-20-2016, 01:16:09 AM
I have seen more then one video with this carb on a best wheel tractor and on a few crawlers now that i have looked in to it more
Holt 75 AultmanTaylor Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 19 06-16-2011 05:37:30 PM
Holt T-16 40-60 (10 ton) A Martinson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 10 12-12-2010 06:42:20 PM
Holt 45 DaveE Multi-Cylinder Stationary Gasoline Engines and Power Units 1 05-07-2009 06:00:01 PM
Holt 18 jbo.aermotor Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 01-26-2009 03:12:48 PM
Holt 18 jbo.aermotor Antique Farm Tractors 0 12-04-2005 08:02:23 PM
