Bedford 500 Turbo MT Engine - question
this thread has 1 replies and has been viewed 810 times
Old 11-13-2016, 03:28:09 AM
petemurphy petemurphy is offline
Default Bedford 500 Turbo MT Engine - question
Bedford 500 Turbo MT Engine (bus) Factory built turbo Distinction - 8 bolt fly wheel, rear seal is lip type bolted onto back of engine, minimech (CAV) mline fuel pump. Need to know degrees BTDC that number 1 piston injects (or measurements)
Currently on the flywheel there is two marks 00 top dead centre and 31 degree mark, these are not correct.
Does anyone have any information about this please or know someone who could provide this?
Old 11-13-2016, 07:04:50 AM
oldgoat 47 oldgoat 47 is offline
Default Re: Bedford 500 Turbo MT Engine - question
Had a look in my manual and it does not give the timing in degrees. It just says to line up the pump pointer with the mark on the coupling. Then the mark on the flywheel should be in line with the pointer on the clutch housing. Send me a pm and I can send you the couple of pages but it won't tell you much more than that. 31 deg sounds about right.
Onan 20 DNAF turbo diesel. Wet stacking or bad turbo seal? Golden Zia Onan Generators 104 03-20-2016 01:34:18 PM
Lincoln SAE 300 with Bedford engine 97fordguy970 Welding Shop 10 02-03-2016 12:10:06 AM
Onan turbo diesel. Wet stacking or bad turbo seal? Golden Zia Onan Generators 2 01-26-2016 08:41:52 PM
Turbo-Charged Steam Engine Gary K Steam Stationary Engines, Traction Engines 6 05-22-2011 07:59:36 PM
bedford gas engine, bedford indiana ??? Nathan Grissom Small Air Cooled Gasoline Engines 3 02-27-2007 10:44:26 PM
