Associated not starting
this thread has 5 replies and has been viewed 875 times
Old 12-27-2016, 04:38:14 PM
djs6446 djs6446 is offline
Default Associated not starting
Hey everyone I picked up my first engine about a month ago. Im still learning about them and Im having an issue with starting it. once it starts it will run but it gives me a fit getting there. Ill soak cloth in gas and put that in the intake, That will make it fire but when i pull the cloth out to try again gas pours out of the intake and it will not start. Thought i was flooding it but wont start with a lean mixture at all. Checked the ball valve and spark. both are good any help will be appreciated. I apologize for the novice questions. Thanks for any ideas or thoughts
The Following User Says Thank You to djs6446 For This Post:
Old 12-27-2016, 05:17:48 PM
Antiquengine Antiquengine is offline
Default Re: Associated not starting
Does the engine have a particular model. And do you know When it was made.and how many hp
Old 12-28-2016, 02:59:31 PM
All I know is it's a 1 3/4 horse associated and the guy I bought it from said it's a 1909
Old 12-28-2016, 05:25:57 PM
Early date indeed
---------- Post added at 05:19:01 PM ---------- Previous post was at 05:09:37 PM ----------
Do you know if it's like a busy boy, choar boy, hired hand, mule team ?
---------- Post added at 05:25:57 PM ---------- Previous post was at 05:19:01 PM ----------
Can you post a picture of it
Old 12-30-2016, 12:08:28 AM
S. Williamson S. Williamson is offline
1 3/4 is a chore boy. There are a couple common associated issues to check for. Make shure the gas tank vent in the cap is correctly venting if no vent or a clogged vent the tank will create pressure and force fuel out of the carb. Also check to make shure the check valve is orientated correctly. Fuel should only flow when the carb has a vacuum present. And if the intake valve spring is weak the intake valve will flutter while the engine is coasting causing the carb to keep pulling fuel and will cause a dripping carb. If the engine is equipped with the older style pancake carb a small amount of fuel dripping from the carb is normal. It's not uncommon to see a cup added under the carb to catch the over flow fuel.
I just seen another post about this engine and it shows a heavily modified carb that is most likely your issue I'd check the listed above and if every thing test ok repair the carb back to original or find a replacement.
The Following User Says Thank You to S. Williamson For This Post:
Old 12-31-2016, 10:08:34 AM
[IMG]associated hit and miss[/IMG]
Yes my carb isnt original by any means. ill check what you said and see what happens thank you. Heres a pic of the engine
---------- Post added at 08:49:00 AM ---------- Previous post was at 08:42:00 AM ----------
---------- Post added at 08:58:26 AM ---------- Previous post was at 08:49:00 AM ----------
---------- Post added at 09:01:55 AM ---------- Previous post was at 08:58:26 AM ----------
---------- Post added at 09:08:34 AM ---------- Previous post was at 09:01:55 AM ----------
im out of town and the computer im using wont let me post picture. It is a chore boy though. thank you for the help
F/M 6hp starting with mag Chris Steffen Hit & Miss Gas Engine Discussion 5 04-13-2010 11:16:30 PM
IHC LA Not Starting Birddog58 Hit & Miss Gas Engine Discussion 10 03-23-2010 07:56:44 PM
Starting 5.0CCK with starting fluid, other? w peterson 54 Onan Generators 4 03-13-2008 02:19:42 PM
just starting john dodd Scale Model Engineering 6 03-18-2007 03:22:19 PM
Starting Engines with Starting fluid Benny Mckheean Antique Engine Archives 22 02-02-2001 11:23:41 PM
