New Toy, 8 Inch Shaper
this thread has 11 replies and has been viewed 1463 times
Old 10-25-2017, 12:31:21 PM
Tanner Remillard's Avatar
Default New Toy, 8 Inch Shaper
Bought a new toy last weekend. 8 inch Shape-Rite shaper. I never thought I would own a shaper as they kind of went by the wayside but they are actually quite handy if you're not in a hurry. Plus when I found out about this little guy I had to have it.
ID:	294326   Click image for larger version
The Following 5 Users Say Thank You to Tanner Remillard For This Post:
Old 10-25-2017, 12:32:54 PM
Default Re: New toy, 8 inch shaper
For some reason my phone always posts sideways pics no matter how I rotate it....
Old 10-25-2017, 01:41:11 PM
A gunsmith friend has a similar sized shaper and it's amazing how good of a surface finish can be obtained on it. That's a machine I'd set up for a long cut, sit back with a few beers and just watch and listen to it run.
Yeah the old saying is true. 'You can make anything on a shaper other than money'.
Sideways and upside down pics are most prevalent on iphones as they have some screwy algorithm for the rendering.
The Following 2 Users Say Thank You to I like oldstuff For This Post:
Old 10-25-2017, 10:44:29 PM
BillWojo BillWojo is offline
Default Re: New Toy, 8 Inch Shaper
Make a boring bar type of tool holder for it and you can now do internal keyways. Back when I was a maintenance machinist it's how I did keyways that were wide and long and to big to push a broach through with the arbor press we had. Scribe the shape on the end and cut to the lines. Very handy machine.
BillWojo
The Following User Says Thank You to BillWojo For This Post:
Old 10-26-2017, 10:16:18 AM
AngrySailor AngrySailor is offline
Very cool! I've always wanted one, even a small vertical shaper that would attach to the arse of the ram on my mill would be handy! Internal key slots, square internal corners... Its one of those machines you probably wont use much but when you have one you'll find/make uses for it! Good score!
Old 10-26-2017, 11:11:47 AM
ronm ronm is offline
I have a 7" South Bend shaper I picked up off craigslist several years ago. Neat little machine, it works but could use some cleanup & restoration. I have a piece of square bar I put in it & take a cut off of when I just want to watch it run...
Somebody put a 3450 RPM motor on it, I need to change that-it runs too fast on any but the slowest pulley.
The guy also had a little Atlas horizontal mill, he wanted to sell both as a package deal so I got it too, it needs a little more TLC to be runnable.
Smokstak member #442
Old 10-26-2017, 11:16:32 AM
typak typak is offline
Nice machine, looks like it has the tilting table as well, some shapers had a power feed option for profiling on the tool holder slide which is great if you can find one, this one found its way home recently and will be a good addition to the shop, no power feed on the tool slide but not complaining!
The Following User Says Thank You to typak For This Post:
Old 10-26-2017, 12:12:29 PM
JoeCB JoeCB is offline
Shapers are cool ! , Follen out of favor in the commercial shop these days due to slow production rates but there are still jobs that only a shaper can do. For instance I recently encountered a project requiring a blind ( dead end) key slot inside a bore (think a bayonet fitting). My little Atlas 7 " shaper answered the call.
Joe B
Old 10-28-2017, 01:30:14 PM
I know, several years ago there was a big old shaper sitting outside a local machine shop in the weather, they moved it out to make room for a CNC machine. Probably went to scrap-sad, but I didn't have a place for it at the time...still don't, really-it was a big old puppy.
Old 10-28-2017, 11:35:18 PM
OTTO-Sawyer's Avatar
Photo Re: New Toy, 8 Inch Shaper
I'm pretty happy with my little Shaper.
Passed one up at an auction 30+ years ago and had been kicking myself ever since so when I finally stumbled across another one 6 years ago I didn't hesitate a bit in buying it.
Name:	Rockwell Delta  Shaper.jpg
ID:	294629   Click image for larger version
Name:	Shaper Cabinet.jpg
The Following 2 Users Say Thank You to OTTO-Sawyer For This Post:
Old 10-29-2017, 11:27:33 AM
How is that wooden cabinet working out? Seems like the factory steel cabinet on my South Bend has got a little loosey-goosey. I think it was owned by an old gunsmith before, so it has seen some use...can't remember if the ol' hippie I bought it from told me that or not, but I got the idea somehow it came from a gunsmith's shop.
Old 10-29-2017, 02:55:21 PM
So Far So Good.
While they were made to be Portable for taking the machine to the job instead of hauling all the parts to the machine mine has relatively "Low Mileage" on it as it came from the local Newspaper where it saw little use beyond cutting down the print plates.
I had it in my garage for a few years where rain & snow occasionally blew under the door and the bottoms of the legs got a little soft but other than that it's in great shape.
---------- Post added at 01:55:21 PM ---------- Previous post was at 01:53:48 PM ----------
Oh, and I believe IT is a Factory Cabinet too.
Cincinatti Shaper Sonny Reese Machine Shop and Tool Talk 10 12-16-2013 01:43:59 PM
Shaper AND a mill? ronm Machine Shop and Tool Talk 1 11-10-2010 03:21:29 PM
Shaper Machine!? 1917Peerless Machine Shop and Tool Talk 1 09-05-2010 06:17:50 PM
Old Shaper Junkologist Machine Shop and Tool Talk 4 10-04-2006 01:03:41 PM
