Unusual Ensign Carburetor for....
this thread has 7 replies and has been viewed 583 times
Old 02-19-2019, 11:30:46 AM
Question Unusual Ensign Carburetor for....
A friend asked me if I knew anything about this Ensign carburetor . What engine/tractor it may fit (Moline), and how it is supposed to function. It sure is a complex one with a spark plug in the lower section and a glass jar on top of the air intake. Any one have any ideas about this new found item . We're just trying to have some "FUN", even in NJ before the big snow storm .
ID:	329001   Click image for larger version
ID:	329002   Click image for larger version
Make a new friend today, and a lot on the way through . Paul-"OLDIHC" #227
My YouTube channel : https://www.youtube.com/user/njoldihc
Old 02-19-2019, 12:11:15 PM
naylorbros naylorbros is offline
Default Re: Unusual Ensign Carburetor for....
That whole set up is an Ensign Kerosene carburetor. How all of the extra stuff that Ensign added to their normal carburetor was to help with burning kerosene I have not idea. Guess I need to spend some time looking at patent applications. What that one would fit, I have no idea. I have wanted to add one to my Ensign collection.
Thanks
Ken
The Following User Says Thank You to naylorbros For This Post:
Old 02-19-2019, 06:56:22 PM
Hi Team,
hopefully this pdf scan of the Patents explains the carb.
Came up on here or ACMOC some time back and luckily I saved it after someone else did the search work.
Cheers,
Eddie B.
The Following 2 Users Say Thank You to eddie bedwell For This Post:
Old 02-19-2019, 11:23:32 PM
Eddie: Thanks for the link to the diagrams of the carb. With the patent # I was able to get the description as given to the patent office. Quite a complicated device. Here is the link to the patent information for those interested:
https://patentimages.storage.googlea...sfh0clWZtIfQNs
The Following User Says Thank You to Paul Spence For This Post:
Old 02-20-2019, 12:15:19 PM
Cat was one of the users of this type of carb. but the reason that I did not say Cat is the flanges on it do not look like anything I have seen in Cat drawings.
Ken
Old 02-21-2019, 11:01:06 AM
After several inquiries, I think this carburetor could be an attempt at providing an economical replacement for the Moline Universal -D Holly gas carburetor to run them with a heavy fuel/gas mixture to save $. It's just my guess . Maybe someone knows for sure, I sure don't .
Old 02-21-2019, 11:12:21 AM
Regardless, it is a most interesting piece of ingenuity. It would be fun to play with...out of doors...where there is no chance of burning down the barn. Having to, essentially, set the carburetor on fire in order to start the engine is, well, something that might be difficult to get UL approval for.
Thanks for sharing!
Kirk
Old 02-21-2019, 11:40:49 AM
PaulGray's Avatar
PaulGray PaulGray is offline
Packard made a similar rig for their cars called a "fuelizer". If you search some of the old Dyke's books from the 20's..you'll see it depicted. I once restored the ignition coil for one of them many moons ago...
The Following User Says Thank You to PaulGray For This Post:
Ensign Carburetor Ssonny Carburetors, Mixers, Fuel Pumps and fuel delivery 1 05-20-2018 10:14:26 AM
Huber 40-62 Ensign Carburetor? d21smith Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 0 01-15-2013 02:14:12 PM
Ensign carburetor hbnwbill Hit & Miss Gas Engine Discussion 2 08-14-2012 10:49:17 PM
IHC Ensign Carburetor ID Craig Weisner Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 11 05-21-2012 05:50:48 PM
Ensign Carburetor and Air Cleaner? What does it fit? Oilpullman Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 5 05-02-2012 10:33:51 PM
