Go Back   SmokStak > SmokStak® Shop Equipment Tools and Techniques > Hardware
Hardware Nuts, Bolts, Washers and Miscellaneous Fasteners
Hardware
What are these nuts called and are they replaceable
this thread has 6 replies and has been viewed 588 times
Old 08-19-2019, 09:48:00 PM
Default What are these nuts called and are they replaceable
This is a really decent seat that fits the Wheel Horse A-60 I have. I want to use it BUT 3 of the nuts are missing out of the bottom of the seat.1 fell out rusted and it appeared to have some clips to lock it in or something.BUT if these are replaceable,I need to know the correct name for them so I can find them. Thanks for the help.
This pic shows 1 of the nuts in it's place to the right,and the left 1/2 inch square hole is where another should go.
Name:	DSC00032 (Medium).JPG
Old 08-19-2019, 10:03:53 PM
Jake Jacobs Jake Jacobs is offline
Default Re: What are these nuts called and are they replaceable
Google weld nuts(Granger) or captive nuts. This will get you started.
The Following User Says Thank You to Jake Jacobs For This Post:
Old 08-19-2019, 10:28:42 PM
Look at the snap in nuts at mc master carr
The Following User Says Thank You to J.B. Castagnos For This Post:
Old 08-19-2019, 11:01:55 PM
Thanks folks! got the info I needed thanks to you alls help.Now I just gota determine 1/4 or 5/16ths before I order them.
20 bucks is alot for 12 nuts BUT the cheapest I can get a low back seat for the machine is about 45 so to have it's original seat with the horse logo on it for 20,and have the spares,I guess it will be worth it.
https://www.ebay.com/itm/The-Hillman...gAAOSwFYJbxIXH
Old 08-20-2019, 05:14:47 PM
OTTO-Sawyer's Avatar
If it wasn't for the big square hole to fill I'd go with the "Riv-Nut" or "Nut-Sert" pop-rivet style nut insert.
With that big hole I'd probably just spot-weld a nut to it and call it done.
Old 08-20-2019, 05:54:05 PM
Any chance you could put a carriage bolt from the top with a fender washer and regular nut on the bottom? just thinking
Old 08-20-2019, 09:08:30 PM
That is a maby.OF all things I forgot to check to see what size I need as far as 5/16 or 1/4. I have been under the hood of my dads old Dodge truck Again most of the day.
What's it called? Deerlope Oilers, Lubricators and Grease Cups 2 09-18-2017 10:55:59 AM
This would be called? opus Onan Generators 10 08-22-2016 01:11:42 PM
What is this called, and where can I get one? packrat56 Hit & Miss Gas Engine Discussion 2 11-19-2011 09:09:40 PM
Anyone know what this is called? WilliamInOz Smokstak Down Under 2 05-25-2009 03:16:06 PM
