Tractor Identification in Old Photo
this thread has 11 replies and has been viewed 1314 times
Old 07-04-2019, 09:09:01 AM
CBarth66 CBarth66 is offline
Default Tractor Identification in Old Photo
I was going through my Grandfather's old photo album and saw this picture. Though he was from Ohio, he and his brothers went to Iowa for a time to work. I think that is what my Grandmother told me, but it's hard to remember everything as she told me so much about the old days. She died a little over a year ago at 111 years old. Anyway, I think this picture is from when they were in Iowa. Can anyone tell me what this tractor is? Sorry for the poor picture quality. It is very old.
Old 07-04-2019, 09:20:37 AM
casertractor casertractor is online now
Default Re: Tractor identification in old photo
Looks like a early Nichols and Shepard gas tractor? maybe 22 hp or 36 hp?
The Following 4 Users Say Thank You to casertractor For This Post:
Old 07-04-2019, 10:13:24 AM
FWurth's Avatar
FWurth FWurth is online now
One Millionth Post
It is a very early version 35-70 N&S oil- gas tractor. The horizontal section radiator and light channel frame were only used a very short time. None of this version seems to have survived. Large 2 cyl engine with a steam type fly ball governor, produced around 90 hp at low rpm. They were designed primarily for plowing the vast prairies. I have a old photo of one on a sawmill , empty fuel barrels all around the site! Had one of those early carbs with the steel balls that lifted as the load increased. Very inefficient and used enormous amounts of fuel. One of the big reasons these units were parked.
The Following 7 Users Say Thank You to FWurth For This Post:
Old 07-04-2019, 10:26:07 AM
Did all the early ones have full cabs on them?.The one in the picture looks like they took some of the cab apart for better viewing
Old 07-04-2019, 11:03:48 AM
FWurth's Avatar
One Millionth Post
The only photo I've seen of one without a cab was of the prototype during field trials. I agree that in the above, they've removed a few panels for visibility or ventilation. Like the early Hart Parrs, the channel iron frame was too light and would bend and twist under load and soon failed. The later versions in all sizes had a heavier plate steel frame, those were a much better foundation and kept the gearing in better alignment and less wear. It's really a shame that more of these didn't survive, when in good repair, they were quite the brute for power. I did for a while have the remains of one of the 3 that survive, hopefully at some point it will be reconstructed into a working tractor again.
The Following 3 Users Say Thank You to FWurth For This Post:
Old 07-04-2019, 02:04:37 PM
Default Re: Tractor Identification in Old Photo
Thanks for the replies. That photo must have been taken somewhere in the 20's, because he was out there before he got married in the 30's. When you say that tractor was one of the earlier ones, what years would that be?
The Following User Says Thank You to CBarth66 For This Post:
Old 07-04-2019, 02:14:12 PM
The Early teens
The Following 2 Users Say Thank You to casertractor For This Post:
Old 07-04-2019, 04:56:17 PM
FWurth's Avatar
One Millionth Post
N&S built the prototype in 1911. They sporadically built the various versions till around 25, after that they offered a rebadged Lauson product till the merger with Oliver in 1930. N&S's big contribution to the merger was the combines and a corn picker and the factories, no tractors as Oliver and Hart Parr had that covered. The Great Depression and the Dry 30s was in full force out on the farm till the outbreak of WWII, any new purchases of modern tractors was put off till after that. Most early tractors that farmers had were in use far past their original expected life. So it is very likely that this one was still working well into the 30s. Also these N&S tractors were very popular in the Red River Valley of the North area. I think all surviving ones did come from that part of the country. There were a few odd ones in the lower Midwest, but not many. There was rumors of one in the local area that disappeared during the scrap drives of WWII.
Old 07-04-2019, 07:01:22 PM
Now to figure out what make of engine gang plow it is pulling behind it?.John Deere,Cockshutt or P&O (Parlin & Orendorff)?.Maybe a Rumely or Avery? Case-Sattley? Rock Island? could it be a Oliver?
Old 07-04-2019, 09:51:11 PM
halcon halcon is offline
When the cab panels where removed, they soon discovered the roof needed the panels for bracing but some good ole wire did the trick. Those 360 degree crankshaft engines tend to make things shake.
The Following 6 Users Say Thank You to halcon For This Post:
Old 07-15-2019, 05:37:09 AM
AndyMoravec AndyMoravec is offline
Can you share this old photo? That would be cool to see!
Thanks!
Old 07-15-2019, 10:42:50 AM
FWurth's Avatar
One Millionth Post
I'm a bit technically challenged but if you Google Early Nichols & Sheppard photos , you will get many pictures of them and a few of the prototype. Also there were a good bunch of photos in the Willard libaray collection, but I'm hav ing trouble finding them just now. Also try google under- Nichols & sheppard collection by James Hawthorne. Also check other threads here on site relating to N&S Gas tractors.
Jelbart tractor see photo Gene Fisher Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 19 09-22-2012 09:24:39 PM
Homebuilt Tractor photo Grape Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 10 06-02-2010 07:21:10 PM
Old tractor photo Andrew Yeary Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 8 11-14-2008 08:07:52 AM
Tractor photo wanted OldAgIron Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 01-01-2008 10:31:21 AM
rare Russell tractor [?] tractor photo postcards Sawyer-Massey 11-22 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 07-01-2006 07:24:43 PM
