Ford 900 series hydraulic problem
this thread has 2 replies and has been viewed 2297 times
Old 04-09-2012, 08:28:18 PM
rghanson rghanson is offline
Default Ford 900 series hydraulic problem
Hi,
I have the Ford 961, that my dad bought new in 1958. It sat for way too long without the hydraulics being used, as a result the hydraulic control system was quite rusty. The pump still puts out 2000 psi and the loader works fine, but the three point hitch is very weak and cannot hold a load without dropping even at moderate engine speed. I have changed oil several times and added a couple cans of Sea Foam last year.
Any great ideas?
Thanks,
Dick
Old 04-09-2012, 10:46:16 PM
model k rumely model k rumely is offline
Default Re: Ford 900 series hydraulic problem
the seals for the 3 point cyl. need to be replaced, or the control valve needs the same. I would check the cyl. first
Old 04-09-2012, 11:12:27 PM
try this site.John
http://www.ntractorclub.com
Clark Forklift Hydraulic Problem, no flow to cylinder reservoir dalmatiangirl61 Lifting and Loading 17 04-08-2019 09:12:14 AM
Cummins A Series (Onan L Series) L423D fuel pump problem? ichudov Onan Generators 23 09-22-2015 08:36:44 PM
560 Farmall hydraulic hitch problem jgiesler Antique Farm Tractors 8 01-27-2014 02:00:31 AM
Ford 9N Hydraulic Pump Repair drofnasd Antique Farm Tractors 3 10-16-2010 10:46:46 PM
N series ford tractor Ihorse Antique Farm Tractors 4 07-12-2007 09:56:23 AM
