F-12 Front Wheel and Axle
this thread has 5 replies and has been viewed 1663 times
Old 04-10-2012, 08:01:48 AM
chattblacksmith chattblacksmith is offline
Cool F-12 Front Wheel and Axle
Good Morning All
So the story goes. I was given a F-12 by my uncle who had made an attempt to restor it twenty or so years ago. It is not a bad tractor it has been sand blasted and put back in primer. The engine is stuck, not bad I think but I am intending on doing a rebuild anyway. The issue Is that it has a front wheel on it that I have never seen befor on a F-12. I am sure it is factory but I am more of a JD guy so I will ask the experts. This is a single front split wheel type that weighs every bit of 100 lbs and has four long bolts that hold it togeather. The wheel bolts around the axle and wheel bearings. But it is unlike any other single front wheel F-12 I Have seen befor. The axle looks like it has been run without bearings for some distance so it is not useable and I cant get any measurements off of it to turn another one. If I can find a set of bearings I can pull the I.D. and make a new one. It looks to have the standard single front steel wheel mounting system and I do not know if I can use the standard single front wheel axle of bearings. If any one has info on this or knows were I can get an axle and set of wheel bearings I would be very greatful.
Chris
Old 04-10-2012, 08:13:02 AM
falconry63 falconry63 is offline
Default Re: F-12 Front Wheel and Axle
doe it look like this one?
Old 04-10-2012, 08:14:15 AM
That is the one Sir.
Old 04-10-2012, 04:25:36 PM
Titan1020 Titan1020 is offline
That is a very common F-12 front wheel. You should be able to find parts at any number of places including ones that advertise on this website.
Old 04-10-2012, 08:45:39 PM
go to the fordson house they have it part #2970DX Hope that helps
Old 04-11-2012, 04:36:07 PM
Thanks for all of the help guys!!
waterloo front axle and wheels Walter Neumann jr Live Auctions of Engines, Tractors and Old Iron 2 03-21-2012 09:43:28 PM
Farmall a or a1 with square front axle larry bee Farm Antiques and Collectibles 4 12-26-2011 08:35:21 AM
Rumely M 20-35 Front axle Norm Johnston Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 9 12-10-2011 05:28:21 PM
Front axle identification John Hamilton Garden Tractors and Mowers 0 02-19-2009 04:24:52 PM
Need pic Large IH cart front axle Roger White Antique Engine Archives 1 08-22-2000 02:11:51 PM
