IHC 3-5 LB measurments
this thread has 10 replies and has been viewed 1251 times
Old 01-13-2013, 07:03:19 PM
Preston Wells's Avatar
Preston Wells Preston Wells is offline
Default IHC 3-5 LB measurments
I need a couple of 3-5 LB measurments.
1) Overall length of the piston/rod, otherwords from the top of the piston to the flat machined surface of the con rod(this will measure to 1/2 the crank pin diameter).
2) Crank pin diameter
3) Crank pin width
Thanks for looking
"There is more to life than what we see"
www.youtube.com/user/theoldengine1
Preston
FL
Old 01-14-2013, 01:47:49 PM
6hpMarty 6hpMarty is offline
Default Re: IHC 3-5 LB measurments
I could use the size of the bore, and the length that a sleeve would be to bore and sleeve a 3-5 ihc lb. (my cylinder blew out)
Old 01-14-2013, 03:35:25 PM
oldproff oldproff is offline
I might up to my shop tomorrow. If I do I can get these measurments for yall. I have a 3 to 5 torn down and I hope to start putting it back together tomorrow. Bill K
The Following User Says Thank You to oldproff For This Post:
Old 01-14-2013, 03:46:38 PM
midpw midpw is offline
I have a 3-5 in storage down the road that I finished up last spring. It was a fun project but now it just sits there. Hint, hint
Bruce
Old 01-14-2013, 04:44:49 PM
PistonRing's Avatar
PistonRing PistonRing is offline
Banner Sponsor
Hi Marty-
I don't have one apart right now to measure the sleeve length, but a 3-5 LB takes three 1/8" compression rings and a 1/4" oil ring in a 4.0" diameter cylinder. It is really rare to find one that is over sized. They almost never got bored over sized.
Thanks,
Dave Reed
Otto Gas Engine Works
2167 Blue Ball Road
Elkton MD 21921-3330 USA
phone 410-398-7340
http://www.ringspacers.com
http://www.pistonrings.net
Old 01-14-2013, 06:08:41 PM
Ron Haskell's Avatar
Ron Haskell Ron Haskell is offline
As common as these engines are, it woud be FAR cheaper to find another block or another parts engine.
Old 01-14-2013, 06:46:54 PM
Is it commom to have a cylinder rusted so bad it blows out??? Ok do I have any volemteers with a 3-5 lb parts block???? How do I know it will have a good cylinder???? If I bore and sleeve I know it will run a long time???
Old 01-16-2013, 06:20:37 PM
Mesurments for both of you.
Preston, Length of piston/connecting rod; 10 1/2 inches
Crank pin dia; 1 27/32 inches or 47.46 mm
Crank pin width; 1 9/16 inches or39.9mm
My caliper reads in mm and I am not good with metric so I laid it on a ruler to convert.
6hpMarty, Cylinder length is 9 1/2 inches
Cylinder bore is 4 inches
Piston is about 3 15/16 inches
Hope this helps. Bill K
The Following 2 Users Say Thank You to oldproff For This Post:
Old 01-16-2013, 09:14:34 PM
Thank you !!!!
Old 01-17-2013, 08:00:58 PM
Thank you Bill and for all replies. 6hpMarty I have a 3-5 block in storage. I could dig it out and look at the bore condition but you might be better (cheaper) finding one at a local show than shipping cost. Thanks
Preston
FL
Old 01-22-2013, 12:54:14 AM
?? you never know ?? is it shippable by UPS??? I could issue a call tag and have it picked up as long as you come up with a price and are willing to pkg. it for safe passage to iowa???
12 HP Hercules Low Base Gas Tank Measurments Joel Mosley Hit & Miss Gas Engine Discussion 0 01-12-2011 11:10:57 PM
Aermotor measurments needed Kevin Weis Hit & Miss Gas Engine Discussion 2 12-08-2008 06:32:14 PM
GREAT Website for measurments Chris Kirk Antique Engine Archives 2 02-16-2003 05:59:42 PM
