2-1/2hp Schramm Engine
this thread has 9 replies and has been viewed 1742 times
Old 01-15-2013, 11:13:05 AM
Jon Rozevink's Avatar
Jon Rozevink Jon Rozevink is offline
Engine Buyer
Photo 2-1/2hp Schramm Engine
I would like to share some pictures of a 2-1/2hp Schramm engine I picked up yesterday. I was wondering if anyone else has or has seen one of these before. I've had a couple of them that were air compressor engines but I've only seen one other stand alone engine like it.
Here is a link to some more pictures of it.
https://picasaweb.google.com/1007961...SchrammEnigne#
ID:	154998   Click image for larger version
ID:	154999   Click image for larger version
ID:	155000   Click image for larger version
Check out my engine videos at http://www.youtube.com/user/sideshaft08
I want to buy your engines, especially rare ones! http://www.sideshaft.com
Old 01-15-2013, 11:41:55 AM
Doug Kimball's Avatar
Default Re: 2-1/2hp Schramm Engine
Jon,
No, never seen one like this one. Some similarities to Sharples, Toronto, Burkett, etc. Carb is quite different, rocker arm arrangement different, flywheels & gov. weight quite similar. Does not appear to be dual ignition, no speed or spark advance levers. Is Wico PR & bracket original? Cast "X" bracing inside hopper on sides? Oiler pipe cast in place? Is crankguard part of base casting or removeable? Where is spark plug opening?
In Kennebunk, Maine;
Doug Kimball
The Following User Says Thank You to Doug Kimball For This Post:
Old 01-17-2013, 10:22:43 PM
Dan Grace Dan Grace is offline
hi Jon I have a 2 1/2 and a size p that I believe is a 5 hp neither one has a mag I don't think there is to many out there the 2 1/2 belonged to my dad when I was 7 years old he had to sell it. in 27 years it was sold to 2 different people fortunately i was able two by it backdan
The Following User Says Thank You to Dan Grace For This Post:
Old 01-17-2013, 10:44:30 PM
LCJudge LCJudge is offline
Jon, looks like it's very heavy made and would be for industrial rather than farm type applications. I remember seeing one several years ago at a show. Very few out there I would think.
Tommy Turner
The Following User Says Thank You to LCJudge For This Post:
Old 01-18-2013, 07:36:11 AM
J Kocak's Avatar
J Kocak J Kocak is offline
Here is a 2 Hp of mine running, also got a couple air compressor engines. Kind of like the Schramm engines the way they run.http://www.youtube.com/watch?v=ATiy0...5aBsg&index=29
The Following 3 Users Say Thank You to J Kocak For This Post:
Old 01-18-2013, 08:56:45 AM
David Babcock David Babcock is offline
Smile Re: 2-1/2hp Schramm Engine
I had one and sold it about 20 years ago. It was in rough shape. Iam currently trying to buy it back as the current owner has done nothing to it. Db.
The Following User Says Thank You to David Babcock For This Post:
Old 01-18-2013, 09:42:44 AM
I have a stand alone compressor and I am looking for the crowned flywheel for it, mine is missing. If anyone knows of one that might be available, I would be interested. I don't have the dimensions but it is between 24" to 28" in diameter. The crankshaft diameter is 2".
Old 01-18-2013, 10:35:03 AM
JBoogie's Avatar
JBoogie JBoogie is offline
Its odd that the decal is in better shape than the tag. Heres my uncles Schramm.
http://www.youtube.com/watch?v=pIbiR2-9FUk
The Following 3 Users Say Thank You to JBoogie For This Post:
Old 01-18-2013, 10:45:56 AM
Engine Buyer
Originally Posted by Doug Kimball View Post
Jon,
Hi Doug
It is not dual ignition but it does have an advance and retard lever. I'm sure the PR bracket is original. There doesn't seem to be any x bracing. The oiler pipe isn't cast in place. The crankguard is removable. The spark plug is behind the muffler.
JBoogie This engine came not to far from you and your dad's shop. I thought about stopping by but I had to get home for some reason.
The Following User Says Thank You to Jon Rozevink For This Post:
Old 01-18-2013, 07:01:52 PM
Jim Stigerwalt Jim Stigerwalt is offline
Jon, Real nice engine. Here is one I have had around for some time. I need a head and all the parts that bolt to the head. Any parts available?
ID:	155320   Click image for larger version
Domestic/Schramm Engine Tag Gene Fisher Hit & Miss Gas Engine Discussion 2 01-08-2011 01:01:59 PM
Schramm engine-air compressor Andrew Mackey Hit & Miss Gas Engine Discussion 14 09-03-2007 04:27:37 PM
Schramm compressor with Wisconsin engine junkyard4$ Wisconsin Engines 4 05-09-2005 06:05:27 PM
Anyone ever see a Chris Schramm engine? Mike Castner Antique Engine Archives 0 07-29-2002 09:49:17 AM
Schramm / Woodpecker engine Lyle Sundry Antique Engine Archives 0 07-29-2000 10:12:41 PM
