McCormick-Deering 6hp M Fuel Pump Bolt
this thread has 1 replies and has been viewed 1099 times
Old 01-18-2013, 07:29:45 PM
Stevie Stevie is offline
Default McCormick-Deering 6hp M Fuel Pump Bolt
Hello. I was tearing apart my 6hp M and was taking the fuel pump off. The fuel pump if the orginal pot metal as was all cracked and just literally feel part when I took it off. My question is on the stud that holds it there appears to be a sleeve on the bolt. Is this right? I looks like this should come off. I stuck my hand into the back of the engine and felt the bolt head (square). THANKS ALL. This engine is a Spark Plug engine 1927
Old 01-19-2013, 12:10:09 AM
Skip Landis Skip Landis is offline
Default Re: McCormick-Deering 6hp M Fuel Pump Bolt
If i remember right, that sleeve is where the fuel pump drive pivots. You will have to remove the bolt you spoke of & free/ clean things up.
McCormick-Deering 1.5 M fuel pump questions Bob Painter Hit & Miss Gas Engine Discussion 18 04-30-2015 09:04:51 PM
McCormick-Deering M fuel pump (A/C) Stevie Hit & Miss Gas Engine Discussion 2 12-05-2012 09:23:37 AM
McCormick-Deering M fuel pump 1 1/2 - 6hp Stevie Hit & Miss Gas Engine Discussion 2 07-19-2012 03:50:23 PM
McCormick-Deering fuel pump bolt/stud cvti8586 Hit & Miss Gas Engine Discussion 2 08-06-2009 08:19:19 PM
Mccormick Deering M fuel pump mounting? Scheetz83 Hit & Miss Gas Engine Discussion 13 09-01-2007 11:15:58 PM
