6 HP Fairbanks Morse Propane
this thread has 3 replies and has been viewed 1424 times
Old 01-18-2013, 07:49:39 PM
John Schmidt John Schmidt is offline
Default 6 HP Fairbanks Morse Propane
I have a 6 hp Fairbanks Morse ignitor engine missing the carburetor. I am looking for any help I can find to complete a working carburetor for this engine. Is it possible to switch a carburetor from gas to propane? Any help would be appreciated.
Old 01-18-2013, 08:09:15 PM
David M. Lyon's Avatar
Default Re: 6 HP Fairbanks Morse Propane
This 6 horse "Z" hit & miss engine will run on propane, natural gas, or gasoline. But it is a spark plug engine. I'm sure there is a way to adapt the ignitor engine to gas rather than gasoline, but I've never tried it. Gotta' think about this one!~
The Following User Says Thank You to David M. Lyon For This Post:
Old 01-18-2013, 08:16:13 PM
Trying get away from famous fuel pump.
Old 01-18-2013, 10:47:51 PM
KyleBlankenship's Avatar
KyleBlankenship KyleBlankenship is offline
make a plate that fits the mounting where the carb would go.
drill and tap for 1/2 pipe threads in center of plate
get piece of 1/2 pipe 4-6 inches long threads on one end
drill and tap 1/8 hole in said pipe
install a choke plate on end of non threaded end
install 1/8 needle valve
get lp tank, use a gas grill regulator or adapt a accytlene regulator (for controled pressure)
connect with hose
find "sweet" spot and run.. you wil have to choke some air off and tinker with it a bit to find where it runs the best.
ita all pretty straight forward, ive done MANY engines this way. had one giving me some fits so i had to email the professional david lyon.. but other than that. its simple
The Following 3 Users Say Thank You to KyleBlankenship For This Post:
Fairbanks Morse propane conversion Chuck Hall Hit & Miss Gas Engine Discussion 0 08-02-2011 02:43:31 PM
Fairbanks Morse ZD 8HP Propane Setup Tim Vallet Hit & Miss Gas Engine Discussion 3 04-10-2011 10:09:40 AM
Fairbanks Morse ZC-52 3HP on Propane? Tom Herd Hit & Miss Gas Engine Discussion 2 02-13-2011 03:45:18 PM
Fairbanks-Morse ZC52 on Propane David M. Lyon YouTube Old Iron Videos 0 02-12-2011 01:58:31 PM
Fairbanks Morse Z model 52 ? propane ? Dale Freidline Hit & Miss Gas Engine Discussion 12 11-07-2008 11:00:48 PM
