Choke in IHC Famous and Victor Engines
this thread has 1 replies and has been viewed 1109 times
Old 01-18-2013, 10:49:23 PM
jboyer1028 jboyer1028 is offline
Photo Choke in IHC Famous and Victor Engines
Attached are pictures of Pat Barrett's Victor TC engine that was built in the first part of 1914 that doesn't have the choke in the cold air intake. Also attached is my Famous TC engine that was built in the last part of 1914 that has the choke in the cold air intake. I've been told the early Famous engines didn't have the choke but the later ones did. Was a change made in 1914 and IHC started adding chokes to the cold air intake or was the choke not needed on the Victor engines? Or some other reason for the difference?
Jeff
ID:	155347   Click image for larger version
The Following User Says Thank You to jboyer1028 For This Post:
Old 01-19-2013, 12:05:24 AM
Skip Landis Skip Landis is offline
Default Re: Choke in IHC Famous and Victor Engines
I have a 1908 10 horse famous that has the choke, but it is hit & miss. Don't know if that makes a difference.
The Following User Says Thank You to Skip Landis For This Post:
IHC Famous, Titan and Victor Engines jboyer1028 Hit & Miss Gas Engine Discussion 7 02-11-2013 08:16:02 AM
20HP IHC Famous/Victor Jason Dahm Hit & Miss Gas Engine Discussion 10 07-26-2010 03:41:12 PM
IHC Victor and Famous Engines Denis Rouleau Hit & Miss Gas Engine Discussion 4 03-30-2010 07:57:58 AM
IH 6HP Famous--Mogal--Victor Skids Jim Tremble Hit & Miss Gas Engine Discussion 13 06-09-2007 04:02:11 AM
IHC 8HP Victor or Famous ??? oldironcollector Hit & Miss Gas Engine Discussion 4 09-13-2006 07:22:23 AM
