tom thumb carb help required
this thread has 7 replies and has been viewed 1321 times
Old 01-20-2013, 07:10:14 PM
Chuck Foster's Avatar
Chuck Foster Chuck Foster is offline
Default tom thumb carb help required
hi guys
i am working on a tom thumb carb and it looks different than all the other tom thumb carbs i have seen.
the air intake appears to be on the side of the carb body not the bottom (see pictures)
can any one shed some light on this as i have to fix the carb.
the last picture shows a casting of the carb that i am used to seeing on these engines.
thanks for any and all help.
chuck
ID:	155481   Click image for larger version
ID:	155482   Click image for larger version
The Following User Says Thank You to Chuck Foster For This Post:
Old 01-20-2013, 09:55:45 PM
Don Oberholtzer's Avatar
Don Oberholtzer Don Oberholtzer is offline
Card Sponsor
Default Re: tom thumb carb help required
It looks like it was the early style.
The Following User Says Thank You to Don Oberholtzer For This Post:
Old 01-20-2013, 10:13:41 PM
thanks for the info don.
now does anyone have a good picture of what it should look like?
thanks
chuck
Old 01-20-2013, 11:18:54 PM
Tom Marshall Jr.'s Avatar
Tom Marshall Jr. Tom Marshall Jr. is offline
There is a bell shaped piece out the side where it is broke, A choke lever is on one side which opens and closes slots on the big end. Does yours have the brass connecting rod? mine was 1908, can't find a photo of it .Tom
The Following User Says Thank You to Tom Marshall Jr. For This Post:
Old 01-21-2013, 12:00:27 AM
This may help some.
Old 01-21-2013, 08:12:24 AM
thanks for the picture tom
my engine is serial number V 1104 E and they say it was made in 1908 and yes it has a brass rod.
is the gas tank on your engine a copy of the original if so were might i be able to buy one?
thanks allot guys for your help.
chuck
Old 01-21-2013, 08:56:13 AM
Chuck: The tank came with it,has a repair top center and looked quite old.I never seen another like it. original? Tom
Old 01-21-2013, 10:49:21 AM
Card Sponsor
A sponser on Harry's John Wanat has them, close to original as possiable.
4.5 New Way some assembly required Walt Roys Antique Engine Photos 0 06-11-2012 11:23:31 AM
CCK Information required island doug Onan Generators 7 04-22-2010 11:44:19 AM
Engine ID Required BobSaunders Scale Model Engineering 11 09-24-2009 09:10:01 AM
Help required (solenoid) envelopes2007 Onan Generators 5 10-31-2008 03:33:16 PM
Required memberships? Allen Hit & Miss Gas Engine Discussion 36 10-24-2006 07:51:09 PM
