IHC M Welding governor sleeve
this thread has 5 replies and has been viewed 1145 times
Old 01-20-2013, 07:31:25 PM
onstottc onstottc is offline
Default IHC M Welding governor sleeve
On my m the lip of the governor sleeve closest to the flywheel is completely gone. I have another worn sleeve that has a decent lip. Im thinking about brazing or mig welding it to the other sleeve. How well do these stand up to welding or brazing?
Old 01-20-2013, 07:36:22 PM
Brickman's Avatar
Brickman Brickman is offline
Default Re: Ihc m Welding governor sleeve
i wouldnt weld it as there are outhers avalable for sale prety commom engim to find parts for . ron brown in central illinois
Old 01-20-2013, 10:25:41 PM
John Hamilton's Avatar
John Hamilton John Hamilton is offline
They are common but there are differences between ignitor and spark plug sleeves.
Old 01-21-2013, 04:21:17 AM
Ray Cardoza's Avatar
brazing can work if you have a lathe to true it up in after it cools down
Old 01-21-2013, 08:53:05 PM
Default Re: IHC M Welding governor sleeve
I attempted a braze repair, but the lip I cut off of an old governor promptly cracked. I decided to make a new lip and mig weld it into place.
Sleeve with lip missing
Plasma Cutting new lip.
New Lip welded on.
Old 01-21-2013, 09:04:25 PM
Photos did not post..
ID:	155621   Click image for larger version
ID:	155622   Click image for larger version
To sleeve or not to sleeve (cylinder) Mayatag Bob Hit & Miss Gas Engine Discussion 11 01-18-2012 03:26:02 PM
IHC 1-1/2 M Governor Sleeve Stacy Leis Hit & Miss Gas Engine Discussion 7 09-09-2011 07:56:21 AM
Welding a sleeve on damaged shaft at bearing seatings? trakesh2140 Generators & Electric Motors General Discussion 10 04-19-2010 08:51:57 PM
Thoughts on crankshaft welding/ engine block welding Mac Leod Small Air Cooled Gasoline Engines 10 04-14-2008 10:46:02 PM
IHC M Governor sleeve pin Bob Johnson Antique Engine Archives 6 02-19-2003 08:10:29 PM
