1.5hp Sattley Magneto Bracket
this thread has 2 replies and has been viewed 923 times
Old 01-20-2013, 11:17:23 PM
dcwaller66 dcwaller66 is offline
Default 1.5hp Sattley Magneto Bracket
I bought a Wico EK magneto bracket for my Sattley and it ended up not being the correct one. The bracket that I purchased has NF-225 cast on the back. According to the owner's manual, I need NF-133 as shown here: Correct Wico EK bracket on eBay
Comparing the two, it looks like I can make the bracket on eBay out of the bracket that I have. I just need to cut it down some and drill two holes. Does anyone have a drawing of the NF-133 bracket that I can work off of? It looks like the four holes are in a straight line, but I'm not 100% certain.
ID:	155520   Click image for larger version
ID:	155521   Click image for larger version
Old 01-21-2013, 12:34:10 AM
Ironman Ironman is offline
Default Re: 1.5hp Sattley Magneto Bracket
Why hack up a perfectly good bracket when, according to you, the bracket you need is currently available on Ebay?
Old 01-21-2013, 01:45:36 PM
I decided to bid on the one on eBay, it is the easiest route.
The reason I was going to cut the bracket that I have is that I way overpaid for it and before doing enough research about what did/did not fit (hindsight is 20/20 I guess ). I'll take the bracket that I have now and put it on EngineAds. I'm sure there is someone on here that could use one.
Magneto Bracket? What is it? Jim Martin Hit & Miss Gas Engine Discussion 3 01-16-2012 09:16:26 PM
AE 202 Magneto Bracket Rick Strobel Hit & Miss Gas Engine Discussion 10 05-15-2011 04:04:54 PM
Magneto bracket AUSDOK Magnetos, Ignition Coils and Spark Plugs 0 09-01-2009 05:05:13 PM
Ek magneto Bracket From ??? Dale Antique Engine Archives 1 08-17-2003 08:54:41 PM
odd magneto bracket NICK Antique Engine Archives 0 12-17-2002 06:18:34 PM
