Steam Engines
tube surface heating area
this thread has 1 replies and has been viewed 747 times
Old 07-03-2014, 12:36:26 PM
sftyvlv1 sftyvlv1 is offline
Default tube surface heating area
Anyone know the calc for this. Same as area of a cylinder or?
Old 07-03-2014, 01:02:31 PM
Pete LaBelle Pete LaBelle is offline
Default Re: tube surface heating area
Outside surface area for a fire tube, inside surface area for a water tube.
3.1416 x D = circumfrence. That, times the length, will get you the square inch area of your tube of a given length. All measuring units must be the same for the above formulas to work.
Pete
The Following User Says Thank You to Pete LaBelle For This Post:
Heating surface calculations Richard H. Gambrell Steam Stationary Engines, Traction Engines 9 09-12-2013 12:00:19 PM
Surface Rust on Rotor will s Generac Generators (SEARS, etc.) 2 04-10-2009 12:07:39 PM
Surface preparation for old engine. geckolover1234 Paint Shop 2 11-12-2008 10:26:45 AM
Case "Heating Surface Area" Rick Strobel Steam Stationary Engines, Traction Engines 34 01-07-2008 09:54:23 AM
Gasket surface needs repair Eugene Borsoff Antique Engine Archives 4 08-09-2004 10:54:12 PM
