slow running, how slow is good for a herc. engine
this thread has 2 replies and has been viewed 3283 times
Old 10-01-2004, 09:14:28 PM
Default slow running, how slow is good for a herc. engine
Hello, I have successfuly made my hercules 3 hp run at 128 RPM, I am working on the fuel mixture, it will only run for a minute or so before it dies. on high speed it is at 128 rpm, I can not it to get it to run on low speed. any ideas on makeing it run on low? What do you think, slow enough? do I realy need to adjust the timeing? it only has 1/16 of a turn on the fuel valve and the choke plate is closed all the way, with the hole plugged.
Old 10-02-2004, 11:49:58 PM
Vernon
Default Re: slow running, how slow is good for a herc. eng
To put less stress on the rod, crankshaft and flywheels, you need to run the timing a couple of degree after top dead center. This will also make it run slower.
Old 10-03-2004, 11:36:28 AM
I made a few more changes, and when it fires you can barely here it, I cut the fuel/air mix down so much that you can stop the engine by grabbing the fly wheel. The combustion is very slow and I do not imagine that the stress is all that great now. I had it down to less than 100 rpms.
Hercules Engine Running Slow Roughnecks007 Carburetors, Mixers, Fuel Pumps and fuel delivery 7 09-29-2016 08:38:28 PM
Running too slow? Ray Lee Hit & Miss Gas Engine Discussion 8 07-04-2015 05:43:09 PM
SLOW Running bigblock Hit & Miss Gas Engine Discussion 30 12-23-2007 04:48:49 PM
Slow running M ? Dcarpent Hit & Miss Gas Engine Discussion 7 02-10-2006 11:54:24 AM
got my Taylor running slow Jeb Lloyd Antique Engine Archives 3 07-19-2004 02:41:47 PM
