Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm Antiques and Collectibles
Farm Antiques and Collectibles Old belt driven farm equipment: shellers, milkers, threshers and pumps.
Band Saw
this thread has 5 replies and has been viewed 309 times
Old 09-10-2019, 09:48:17 AM
Wayne Riedlinger Wayne Riedlinger is offline
Default Band Saw
We recently acquired this large bandsaw. Quite good shape so shouldn't take much to get it going but we will have to buy a blade for it. Would this saw have been used more for wood working or for metal
ID:	343718   Click image for larger version
ID:	343719   Click image for larger version
The Following User Says Thank You to Wayne Riedlinger For This Post:
Old 09-10-2019, 11:16:34 AM
Tom Stockton's Avatar
Tom Stockton Tom Stockton is offline
Member
Default Re: Band saw.
The deep depth of cut sure looks like it's for wood.
Tom Stockton
Old 09-10-2019, 12:21:15 PM
CharlieB CharlieB is offline
Nice find !!!
This one is for wood.
Set it up for a blade speed of about 3000 feet/minute.
Blades are readily available Online welded to any length.
Old 09-10-2019, 12:49:07 PM
DustyBar DustyBar is offline
Its also easy to make your own blades from bulk blade material. Grind the ends on a bevel to let them overlap about 1/4" and silver solder. That type of saw would only be for wood.
Old 09-10-2019, 11:01:27 PM
ulgydog56's Avatar
Default Re: Band Saw
nice find, flat belt hook her up...
Old 09-11-2019, 08:36:19 AM
PFT's Avatar
PFT PFT is offline
For blades: www.sawblade.com
Good blades made to any size you need.
PT
Broadcast Band DX Contaucreek Amateur "HAM" Radio 11 06-01-2019 12:21:11 AM
Band Saw 0002tense Machine Shop and Tool Talk 14 04-01-2011 06:11:41 PM
16'' doall band saw Brian.P Machine Shop and Tool Talk 4 11-17-2010 01:44:58 AM
Which way does the mag band go? Tim Claremont Hit & Miss Gas Engine Discussion 2 01-15-2009 11:10:51 PM
