Cushman Huskey Engine Help
this thread has 3 replies and has been viewed 281 times
Old 08-06-2019, 09:45:16 AM
Nebraska Cowboy Nebraska Cowboy is offline
Default Cushman Huskey Engine Help
I need help on Husky Engine nomenclature. I have a Cushman Motor Scooter Husky Engine, Model is M70, 4 hp, serial numberA43620.
When I look at parts books to order parts, all I see is the designations of piston and ring sizes and M5, M6, M7, etc.
Is my engine considered a M7?
Thanks in advance for any help!
Old 08-06-2019, 04:54:53 PM
Dick DeBuse Dick DeBuse is online now
Default Re: Cushman Huskey Engine Help
M denotes air cooled
6 = 2-3/8" bore
7 = 2-5/8"
8 = 2-7/8"
9 = 3"
10 = 3-1/2"
Number following the bore designation indicates magneto rotation.
Odd denotes counterclockwise, even denotes clockwise. Zero is even.
Cast iron scooter engines have a 2 number prefix. These designate the specific magneto and other equipment. The exception is that later Cushman/OMC overhead valve M109 models, both scooter and industrial, have clockwise magnetoes and a 6 digit OMC ID number.
Your M70 engine is a basic industrial 4 hp engine. Note the governor, which was only provided on industrials. It is located on the block below the exhaust port. Scooter engines did not have governors.
Most scooter engines had counterclockwise magnetoes, although some early models such as those with integral transmissions had clockwise.
Cushman obviously didn't want to make it easy to replace their engine with a Briggs. Most late 40s Cushman scooter engines were Model 17M71. Your engine is 2-5/8" bore and most maintenance parts are interchangeable with readily available scooter engine parts. Also 1949 and later engines had a one-piece block. Earlier engines had the block bolted to a base, or engine sump where the ID plate was mounted.
The Following User Says Thank You to Dick DeBuse For This Post:
Old 08-06-2019, 07:03:29 PM
Thank you!
---------- Post added at 06:03:29 PM ---------- Previous post was at 05:53:52 PM ----------
I notice you live in Omaha, NE. I live in Columbus! Any chance you'd be interested in helping us with our engine? We wanted to try to put it on a scooter we have. A Friend of ours who passed away had given us the engine.
Keith Riley
402-563-4819
eMail: rileykeith59@gmail.com
Old 08-06-2019, 07:55:24 PM
Sure, I'll help.
Cushman Husky and Cushman Sears - any help appreciated WmJackson Butt Buggys, Scooters, 4 Wheelers 5 11-19-2014 11:19:43 PM
Cushman 44 engine Max Cox Hit & Miss Gas Engine Discussion 1 02-07-2012 08:37:20 PM
Old Cushman Binder Engine, New Cushman Owner Short Circuit Hit & Miss Gas Engine Discussion 3 05-19-2010 09:06:38 PM
Cushman 15 hp engine help JunkmanIH660 Hit & Miss Gas Engine Discussion 7 02-26-2009 12:01:14 AM
CUSHMAN ENGINE sonny Antique Engine Archives 3 11-01-2004 12:42:04 PM
