older engines without greasecups
this thread has 2 replies and has been viewed 1310 times
Old 11-15-2005, 09:59:50 PM
Jim Scott
Question older engines without greasecups
do these engines just get oil in the cup built into the main cap? i am working on a sattley. thanks HARRY!!
Old 11-15-2005, 10:15:55 PM
BDMelon BDMelon is offline
Default Re: older engines without greasecups
if their is no threads for grease cups then it takes oil, i use 75/90 gear lube on mine, when it likes to run . have fun
melon
Old 11-15-2005, 10:27:07 PM
Dan Baalman Dan Baalman is offline
Most of the engines I have with only oil cups instead of grease cups use a felt in the oil cup. I saturate it occasionally when running and they work good. I think the felts are original equipment. Dan
Older Briggs Engines shiftlessguy Small Air Cooled Gasoline Engines 6 06-24-2019 05:50:08 PM
Lawn Boy Ignition Updates for Older Engines? Mr Froggy Garden Tractors and Mowers 2 09-03-2018 06:42:34 PM
Burning Propane in Older Engines toddbailey Hit & Miss Gas Engine Discussion 20 06-18-2017 09:37:16 AM
Gas engines that are a 100 years old or older Brian Riddle Hit & Miss Gas Engine Discussion 29 10-29-2007 07:02:43 PM
