Go Back   SmokStak > SmokStak® Old Iron and Tractor Community > Farm Antiques and Collectibles
Farm Antiques and Collectibles Old belt driven farm equipment: shellers, milkers, threshers and pumps.
Feed Grinder
this thread has 4 replies and has been viewed 4472 times
Old 03-12-2007, 07:59:33 PM
Chris J's Avatar
Chris J Chris J is offline
Default Feed Grinder
We have a stuck old iron feed grinder,that is belt driven and almost all there but we want to get it un stuck, any ideas? The grinding part is all iron and really rusty so any ideas would be great, thanks in advance
Old 03-12-2007, 08:19:57 PM
Default Re: feed grinder
HEAT !!!!!!!! And sometimes, lots of it.
Keep the heat away from any babbit bearings, tho.
Jim
Old 03-12-2007, 09:29:43 PM
Tinker Moats Tinker Moats is offline
i have unstuck a couple grinders i found its trash and rust betwean the steel burs seaparate the burs clean them out and it turns freely usually good luck
Old 04-13-2007, 05:50:59 PM
Jebaroni's Avatar
Jebaroni Jebaroni is offline
I had a large grinder that was stuck (8" IHC feed grinder). I'm thinking yours is a small table mounted grinder, but if it is one of the larger ones that has grease cups, take the grease cups off and clean them out. Refill them with fresh grease and re-install or replace them with grease fittings temporarily. Turn the caps down as hard as you can by hand to force grease into the bearings or until you see grease come out around the side of the bearings. If there is an arrow indicating which direction the flywheel or pulley is supposed to go, try to turn the wheel in the OPPOSITE direction so you won't be trying to grind up whatever may be inside. I have had good success with this method. I would hesitate using much heat as many had babbit bearings and you don't want to melt it out.
Jeb
Old 02-16-2018, 07:46:03 PM
Gristmillman Gristmillman is offline
Hello
This is my first time to use Smokstak so I may need guidance and please feel free to correct me.
I have a little wonder gristmill grinder.
It was partially together when I got it.
Does anyone have any good pics of the eccentric bar where it goes under the steel burr discs?
What is the purpose for this bar? I assume you can attach a small bolster/sifter to it
Thanks in advance for your reply
IHC #4 Feed Grinder Jim Walker Hit & Miss Gas Engine Discussion 0 01-14-2011 06:27:18 PM
Feed Grinder toytractor1 Farm Antiques and Collectibles 3 10-25-2010 06:14:58 AM
feed grinder Chris J Farm Antiques and Collectibles 3 05-21-2007 01:34:51 AM
IHC Feed Grinder Colin Rush Farm Antiques and Collectibles 8 01-12-2007 01:46:21 PM
feed grinder craig Antique Engine Archives 0 07-18-1999 11:36:40 AM
