Mega fire or Nova to fire Wico??
this thread has 3 replies and has been viewed 5343 times
Old 02-25-2008, 02:27:39 PM
stugguls stugguls is offline
Default Mega fire or Nova to fire Wico??
Hi,
Does anyone have anything good to say about the chips that megafire and nova offer to replace points and condensers.I have several gravely's running wico xh, I use on my properties and continually fight with the tungsten points that seem to be the only ones available these days, platinum being not available for these?
I have installed several chips megafire and nova with disappointing results so far.The spark seems less intense and deteriorates in time,so what is the point?
I have a bunch of extra mags and the coils on the ones I am using show relative resistance and all work perfectly with points, until points do what they do after a few hrs of running.
Anyone else have any positive experience with the electronic triggers or know where one can get real points?
Thanks for your time, John
Old 02-25-2008, 04:53:28 PM
K D Redd K D Redd is offline
Default Re: Mega fire or Nova to fire Wico??
I use the Sten's Mega-Fire chip on my 1979 Yamaha DT-125 and the Wico mag on my Lincoln 180 DC portable welder powered by a THD Wisconsin. I also have modified one to use in a 1928 Allis-Chalmers Model E tractor. I will use them any where I can.
Kent
Old 02-25-2008, 06:15:01 PM
Exclamation Re: Mega fire or Nova to fire Wico??
Burning, arcing or fast wearing points are indicaters of either a mis-matched or failing condenser. A bad condenser will also give poor spark.
Old 02-25-2008, 10:25:59 PM
Robert Haus Robert Haus is offline
I tend to agree with Andrew...a good condenser is essential to proper operation and if you have a good one along with good points, a good coil, and a strong magnet you should have no trouble whatsoever.
...mags are simple and reliable...I run stock mags on a variety of equipment and rarely if ever have a failure......and most of the airplanes I fly in have magneto ignition on them, and I've rarely had trouble there either.
Also, most high performance car engine builders will tell you that a properly set up and tuned stock ignition setup is very hard to beat....you can spend many hundreds (sometimes thousands) of dollars on aftermarket ignition setups and not really see a noticeable gain for it.
JI Case TM Fire Department-largest steam fire engine in US Guy Fay Steam Stationary Engines, Traction Engines 11 02-09-2014 11:26:16 AM
Fire!!!!!!! G Willikers Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 17 12-03-2012 05:39:24 PM
IHC Fire-red SDP Antique Autos and Trucks 3 06-05-2010 10:40:06 PM
IHC M won't fire Dale Freidline Hit & Miss Gas Engine Discussion 16 10-25-2008 10:04:40 AM
