Using grease cups?
this thread has 3 replies and has been viewed 1846 times
Old 10-27-2008, 06:46:10 AM
redfish443 redfish443 is offline
Default Using grease cups?
I'm running a FM dishpan, first time dealing with the grease cup system and would like some advice on the proper useage of them.
My present theory is to grease the mains, rod and governer cups till fresh grease oozes out. Doing such resulted in much grease thrown around and over everything within 1oo feet.
Realizing this, I adjusted the "flow" in the cups, not tightening them down too awful much and cleaning all the overflow grease off to ascertain how much grease was oozing out. My theory now is to just tighten the grease cups down a bit in the morning when I start up then another slight twist after shutting off the engine when it's warm. This seems to work okay.
Please let me know if I'm doing the right thing, I fugured more is better but sometimes too much my bibb overalls look like they have black polka dots on em...lol....
Old 10-27-2008, 08:31:28 AM
Babs8070's Avatar
Babs8070 Babs8070 is offline
Default Re: using grease cups?
thats about what i do with the grease cups. snug them till a little grease comes out then run the engine. i do notice some of the engines i have bought come with the white lithuim grease in them. i was using the cheap farm and home grease it seems to ooze a little more making more of a mess. i switched to wheel bearing grease it seems to make a little less mess. the white lithuim grease also seems a little less messy. hope that helps. craig
The Following User Says Thank You to Babs8070 For This Post:
Old 10-27-2008, 06:11:06 PM
Tim Claremont's Avatar
Tim Claremont Tim Claremont is offline
Default Re: Using grease cups?
As a rule, I get more concerned if there is NOT grease slinging about...
The Following User Says Thank You to Tim Claremont For This Post:
Old 10-28-2008, 07:18:10 AM
DanR
Most of my engines and machinery have grease cups. Clean up the mess and give 1/4 turn every 4 hours of run tine. White grease is not as notable as the black stuff.
grease cups Mark Birdeau Hit & Miss Gas Engine Discussion 1 12-13-2006 08:13:43 PM
IHC Grease Cups hit-n-miss166922 Hit & Miss Gas Engine Discussion 1 01-30-2006 04:34:14 PM
Type of Grease in Grease cups Dale S Hit & Miss Gas Engine Discussion 17 04-16-2005 01:12:06 AM
Grease Cups Ken Adamson Hit & Miss Gas Engine Discussion 2 02-03-2005 06:29:07 PM
IHC grease cups Joseph Musser Antique Engine Archives 0 06-13-2004 12:36:25 PM
