Old tractor photo
this thread has 8 replies and has been viewed 2209 times
Old 11-12-2008, 07:39:06 PM
Andrew Yeary's Avatar
Andrew Yeary Andrew Yeary is offline
Default Old tractor photo
Here are some neat photos I found tonight. Its a 30-60 Fairbanks Morse. Thought it had a very neat lighting system.
Name:	FM tractor.jpg
ID:	43237   Click image for larger version
Old 11-12-2008, 08:03:55 PM
Tanner Remillard's Avatar
Default Re: old tractor photo
I'd be impressed to see that little lady drive that thing around. Neat pictures
Old 11-12-2008, 09:00:56 PM
I saw a photo in the Rumely Collectors' News of an E Rumely with the same setup.......
Hmmmm.......early lighting systems....... how about it?.......
I have an illustration or two of the Avery version for driving a continuous output magento (generator).
Old 11-12-2008, 11:48:49 PM
Randy Reysen's Avatar
Randy Reysen Randy Reysen is offline
Default Re: Old tractor photo
Here is a nice one I found.
Randy
http://content.scu.edu/cdm4/item_vie...E=0&x=350&y=77
Old 11-13-2008, 12:24:57 AM
spfx_dude spfx_dude is offline
As I recall, the large Fairbanks that Randy let me try driving at the Reynolds this fall had a unique lighting system like that. I will have to find the photos I took and post them. Surprisingly, that big tractor handles really well. I was shocked!
Old 11-13-2008, 09:27:00 AM
Craig lets see those illustrations you talked about.
Old 11-13-2008, 06:50:56 PM
Only this ONE I guess Andrew.......
I got this from Jim Erdle a few years ago.
I think the attached scan is sharp enough to get the whole picture but there is a sprocket which either replaces or fits over the magneto drive hub. Then a silent chain drives the lighting generator.
I had a later model KW lighting generator mounted on a Hart Part 28-50 I used to have.......it lit a BIG Bosch light and did a good job too........
The Following 3 Users Say Thank You to Craig A For This Post:
Old 11-13-2008, 10:44:38 PM
greysteam24hp's Avatar
greysteam24hp greysteam24hp is offline
Hey Craig Anderson,
I wondered how many makes of generator lighting? It makes me think it might have had KW on my Greyhound ( Allis Chalmers 20-35 motor)? I have no archival photo on left view of tractor. I noticed there is a large U bolt attached with angle iron on a water pump housing with a half v groove pulley. On a dash I have a generator lighting, kill switch knob with 3 inch overall sheet metal.
Do you have a photo of late model KW? Just curious.
Two photos below....
First photo is from original catalog. Has two lighting on angle iron cab.
2nd photo unrestored Greyhound belongs to Mike H. of Michigan. Note angle iron on water pump housing. Two holes for U bolt. I have seen another tractor with U bolt.
ID:	43291   Click image for larger version
Old 11-14-2008, 08:07:52 AM
JHFoster JHFoster is offline
I wonder if the exhaust whistle was stock on the tractors?
Jelbart tractor see photo Gene Fisher Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 19 09-22-2012 09:24:39 PM
Tractor photo wanted OldAgIron Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 3 01-01-2008 10:31:21 AM
Unknown tractor photo Andrew Yeary Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 2 11-12-2007 03:44:06 PM
rare Russell tractor [?] tractor photo postcards Sawyer-Massey 11-22 Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 1 07-01-2006 07:24:43 PM
