Needle Valve Packing on an Essex Mixer
this thread has 6 replies and has been viewed 1848 times
Old 10-26-2010, 09:02:26 PM
Henry Macomber Henry Macomber is offline
Banned
Default Needle Valve Packing on an Essex Mixer
Recently purchased a 2hp Sparta that has an Essex mixer.The gland nut wich the needle valve passes through has no packing left in it. I made a new knob for the end of the needle valve and while working on it I noticed the packing missing. I'm sure once fuel is put to it there will be a drip of fuel around the needle valve. What can I use to re-pack the gland nut to prevent this? And where can I buy it?
Thank you,
Henry Macomber
Old 10-26-2010, 09:08:18 PM
Jeremy Hartle Jeremy Hartle is offline
Default Re: Needle Valve Packing on an Essex Mixer
I get it locally from some old farm stores or a local fastenal.If you can't find none send me a pm , i have some old and new stuff left,if i can find it.
Old 10-26-2010, 10:40:02 PM
Tom Martin Tom Martin is offline
Email Not Working
The correct packing is graphited string, and it is usually available in the plumbing section of hardware stores, but for your application, a piece of cotton package string rubbed good with bar soap will work just as well. Soap is not dissolved by gasoline.
Old 10-27-2010, 07:31:55 AM
Banned
Tom,
Not to sound stupid here, is cotton string something you can buy or just pull a string from a cotton ball and saturate it with bar soap?
Thank you,
Henry Macomber
Old 10-27-2010, 07:54:50 AM
Email Not Working
The kind of cotton string that I am talking about is fairly soft string about 1/16" in diameter that is sold as a ball. At one time, the US Post Office required that packages be tied with this type string. I usually get it at the grocery store or drug store in the section where they have tape and other packaging products. Just cut off a length and pull it over a bar of bath soap until it is well coated.
Old 11-04-2010, 11:11:30 AM
Banned
Tom,
The cotton string and soap worked great, thanks for the tip.
Regards,
Henry Macomber
Old 11-04-2010, 11:30:34 AM
Jim Sherman's Avatar
Mop string works well too...
Jim Sherman
My website
ESSEX Fuel Mixing Valve Help Needed minimized Hit & Miss Gas Engine Discussion 3 10-01-2009 09:49:47 AM
Galloway Mixer needle valve TomAnderson Hit & Miss Gas Engine Discussion 3 08-07-2008 08:14:27 PM
Needle Valve Packing Material Tim0477 Onan Generators 0 03-20-2007 04:45:02 PM
Needle valve packing Dale S Hit & Miss Gas Engine Discussion 3 04-21-2005 10:01:52 AM
needle valve packing Bruce Antique Engine Archives 1 01-27-2002 10:08:34 AM
