What do these Mags fit?
this thread has 4 replies and has been viewed 1840 times
Old 10-19-2011, 11:27:43 PM
Will Batty's Avatar
Will Batty Will Batty is offline
Default What do these Mags fit?
Any idea on the appilcation for these Mags?
The first is a Edison Type RM with a counter clockwise rotation
ID:	118675   Click image for larger version
Old 10-19-2011, 11:30:36 PM
Will Batty's Avatar
Default Re: What do these Mags fit?
The second is the remains of a Henricks Mag, any idea of its use?
ID:	118677   Click image for larger version
ID:	118678   Click image for larger version
Old 10-19-2011, 11:32:41 PM
Will Batty's Avatar
I have no ideq what this third Mag even is?
ID:	118680   Click image for larger version
ID:	118681   Click image for larger version
Old 10-19-2011, 11:38:19 PM
Will Batty's Avatar
One more for tonight, this mag is a BT-H, and again I have no idea!
Is there a cross reference somwhere on what the different Wico and Fairbanks mags fit. I picked up a bunch of each some are base mount some are flange mount most are single cylinder, some are four cylinder would like to try and find out what they are for! Thanks for any help!
ID:	118683   Click image for larger version
ID:	118684   Click image for larger version
ID:	118685   Click image for larger version
Old 10-20-2011, 03:34:17 AM
Craig Gillingham Craig Gillingham is offline
The BTH I can help with, I reckon it would be a model AS4. They are a starting magneto, usually from a WWII bomber, twin engined. They were hand cranked, the chain off that sprocket probably lead to the hand crank. Can't tell you much more than that.
The Following User Says Thank You to Craig Gillingham For This Post:
I need help I.D. these old mags Wildcat Hit & Miss Gas Engine Discussion 5 09-29-2009 11:40:54 PM
EK mags Byron Roberts Antique Engine Archives 0 02-18-2004 10:56:04 PM
F-M mags Ray L. Medford Antique Engine Archives 3 06-15-2002 06:07:59 PM
Are FM J mags the same a Lucas RS1 mags Adam Antique Engine Archives 0 12-15-2001 03:08:28 AM
Mags C H Hobrat Antique Engine Archives 0 11-05-2001 09:51:04 PM
