Holley Carb on a New Way F type
this thread has 2 replies and has been viewed 1245 times
Old 11-15-2011, 03:26:57 PM
Billy Purves Billy Purves is offline
Default Holley Carb on a New Way F type
I have a Holley carb on a New Way F type that I am restoring.
The engine will start easily and run for about five minutes and then stop and will restart easily.I have altered the float height and now the engine does not smoke but it still loses a lot of fuel through the needle valve, was the valve packed with something? I have fitted a O ring and it has helped a bit.
Carb has been stripped cleaned and rebuilt with new gaskets.
What is the correct way to alter float height?
Does anyone have any spares for sale for the New Way F type?
Regards Bill.
Old 11-17-2011, 09:52:55 AM
Exclamation Re: Holley Carb
I am looking for a float for my F, with the holly carb. The original has delaminated, due to that crap E-10 fuel. The alcohol disolved the protective coating on the float!
Old 11-18-2011, 06:07:38 AM
PaulGray's Avatar
PaulGray PaulGray is offline
Default Re: Holley Carb
Try Otto Gas Engine Works- he may have what you need.
Melted Venturi- Holley 2210 Carb- Why? dalmatiangirl61 Antique Autos and Trucks 9 11-05-2011 06:42:43 PM
What Type of Carb? Tag Reads Economy Type F (Log Saw) Ray T Hit & Miss Gas Engine Discussion 11 11-17-2009 08:48:16 PM
Holley Carb needed wraymor Hit & Miss Gas Engine Discussion 1 04-26-2009 11:07:48 PM
Holley carb on Twin City Phil Johnson Antique Steel Wheel Tractors - Old Iron Lugs and Cleats 13 11-20-2008 01:58:16 PM
1914 Holley Carb Rick Schanlaub Antique Engine Archives 1 06-24-2000 12:26:51 PM
